Vavle cover bolt snapped HELP
Old Jun 15, 2005 | 08:51 AM
Kevlo911's Avatar
Kevlo for President
Man, I was tightening the vavle cover bolt to 40tq and I did not even get close to that much and it snapped. What should I do? Half the bolt is still in the threads.
Old Jun 15, 2005 | 08:52 AM
MaximaSE96's Avatar
Maxima Owner
buy an extracting kit
Old Jun 15, 2005 | 08:56 AM
sterlingmaxima's Avatar
^^^^^^^^^ what he said it is a great tool i think sears sells it i have seen them in action it is good shiot
Old Jun 15, 2005 | 08:58 AM
Kevlo911's Avatar
Kevlo for President
So I have to drill a hole and then use this to take it out?
Old Jun 15, 2005 | 09:00 AM
Kevlo911's Avatar
Kevlo for President
Where do I get a new bolt, these are wierd looking.
Old Jun 15, 2005 | 09:02 AM
prob a junkyard or dealer they are special kinda dummy proof your not suppose to be able to torque it to much that is the way they were designed
maxgtr2000's Avatar
KH3 by popular demand
Yes sir, if you are unsure, have someone who is a mechanic do it, it does take a bit of nerves to do.
Old Jun 15, 2005 | 09:05 AM
bthe's Avatar
Don't forget to use a nice new drill bit. If it's not straight, you could risk damaging the threads and have to retap them.
Old Jun 15, 2005 | 09:06 AM
Kevlo911's Avatar
Kevlo for President
FSM says TQ to 60 and I was no where near that.
Old Jun 15, 2005 | 09:17 AM
Dubbya's Avatar
VK56 Inside
I bought a extractor from Autozone. It comes with bits and extractors. ~$20 for the whole kit.
Just do a search on Autozone.com for extractor.
You may want to use a tap so the bit drills in the middle of the bolt.
Old Jun 15, 2005 | 09:18 AM
njmodi's Avatar
Do I get a tax break?
AAGH! Kevlo - thats 60 inch-lbs, not foot-lbs.... you did see that right?
Sh*t - I had bad luck doing mine and now you're going through some BS too...
Can you believe that mine is still all dismantled - hopefully the gaskets show up tomorrow and I'll put things back together.
Old Jun 15, 2005 | 09:19 AM
njmodi's Avatar
I bought another TQ wrench specifically for this job - since the one I had was too coarse and didn't go down to the low torque levels for these types of jobs.
sdoherty_tjm's Avatar
hey nimodi, where exactly do you live in the burbs?
Old Jun 15, 2005 | 09:21 AM
njmodi's Avatar
You stalking me? Just kidding. I'm in the Western burbs (Naperville, Downers Grove, etc.).
Old Jun 15, 2005 | 09:23 AM
i live in st. charles, hey do you know of any maxima clubs around here?
Old Jun 15, 2005 | 09:25 AM
njmodi's Avatar
Let's not clutter up Kevlo's thread. Move this to PMs or the regional forum.
Old Jun 15, 2005 | 09:39 AM
Kevlo911's Avatar
Kevlo for President
This is a ***** to drill into. Damnit, it is my fault, I did not see the INCH POUNDS
Old Jun 15, 2005 | 09:46 AM
njmodi's Avatar
Is it one of the front or rear bolts? the fronts are at least easier to see/work with. This really .
Old Jun 15, 2005 | 10:15 AM
Kevlo911's Avatar
Kevlo for President
Front bolts of the rear cover. It came out a little bit now it doesnt want to thread out anymore.
Old Jun 15, 2005 | 10:17 AM
Kevlo911's Avatar
Kevlo for President
MF BS, can't I get by w/o bolt #1. I mean its in hte middle all the other ones should make up for it right?
Old Jun 15, 2005 | 10:21 AM
Dubbya's Avatar
VK56 Inside
I did the exact same thing. My mechanic said it wouldnt leak so I drove around for a couple of days until he had time to fix it. Try some PB Blaster.
Old Jun 15, 2005 | 10:22 AM
njmodi's Avatar
I hate to be the bearer of bad news, but if you don't put that bolt in, won't oil seep out of the bolt hole? I mean you have the grommet in there, but you still need the bolt to close the hole...
Old Jun 15, 2005 | 10:28 AM
njmodi's Avatar
Do you have the valve cover off or on right now?
Old Jun 15, 2005 | 10:37 AM
Kevlo911's Avatar
Kevlo for President
The hole is not inside, gasket is. So the hole does not have to do with the oil. All the bolts are on hte outside of the gasket.
Old Jun 15, 2005 | 10:39 AM
njmodi's Avatar
Yes you are right - now that I picture the gasket in my head that makes sense... I wonder why they have the grommets for each bolt then...
You don't have enough thread visible to get a pair of vise-grips around them huh?
Old Jun 15, 2005 | 10:40 AM
Kevlo911's Avatar
Kevlo for President
It's about 1.5 thread out. I cant get a good grip.
Old Jun 15, 2005 | 10:42 AM
njmodi's Avatar
So it sheared flush with the heads' surface?
Old Jun 15, 2005 | 10:47 AM
Kevlo911's Avatar
Kevlo for President
Ahh this bolt extractor SUCKS ***. So close but not close enough.
Old Jun 15, 2005 | 11:24 AM
Kevlo911's Avatar
Kevlo for President
I am about to cry, whats the odds of the bolt extractor breaking too
Old Jun 15, 2005 | 11:28 AM
njmodi's Avatar
I feel for you man. Now its beyond anything I know... try the all motor forum - those guys may have some good ideas...
Old Jun 15, 2005 | 11:32 AM
Kevlo911's Avatar
Kevlo for President
I am just gonna put a bunch of thatr grey gasket stuff there, I am pretty sure all the other bolts will make up for one of hte middle bolts being out.
Old Jun 15, 2005 | 11:53 AM
njmodi's Avatar
That will probably work. I'm wondering, is the oil in the valve cover under any pressure? Or just is just slosh around because of the cams? Just wondering how much work the seals are doing to begin with.
I know you had a leak there before, where was it leaking from? Did you find that your old gasket had cracked?
Old Jun 15, 2005 | 12:41 PM
Kevlo911's Avatar
Kevlo for President
Ehh it was leaking in the rear, the oil would run down the headers onto the ypipe and control arm. So far no leaks and car runs pretty smooth. Good think I put it together quickly, it is raining now.
Old Jun 15, 2005 | 12:52 PM
njmodi's Avatar
Damn - you got it all back together pretty quick - did you pull the IM off the car - or just prop it up out of the way?
Old Jun 15, 2005 | 01:06 PM
Kevlo911's Avatar
Kevlo for President
I took the IM off. I can take out the IM in about 10-15minutes and I can put it back together in 20. I would finished earlier but one of coil packs was not in all the way and I did not know it so the car ran like **** and I didnt know why.
Old Jun 15, 2005 | 01:13 PM
njmodi's Avatar
Damn! look for a thread tomorrow AM titled "I need help putting my IM back on" I'm serious!
So you put the sealent on the corners and around that sheared bolt... how long did you wait for the sealent to set before starting the car?
Did you assemble the valve cover/gasket while the sealent was still "un-set" - I think thats what you are supposed to do.
Old Jun 15, 2005 | 01:29 PM
Kevlo911's Avatar
Kevlo for President
You put the sealant in the gasket groove on the vavle cover, then install the gasket on top of it. I put a little bit in all 4 corners so I knew the gasket would not fall out when I put it on the head. I waited about 20-30min for it to set before I attempted to install.
Old Jun 15, 2005 | 01:36 PM
sx7r's Avatar
like everyone said, screw extractor:
http://www.sears.com/sr/javasr/produ...id=00920616000
Old Jun 15, 2005 | 01:42 PM
Kevlo911's Avatar
Kevlo for President
It broke inside the bolt
Old Jun 15, 2005 | 02:18 PM
RA030726's Avatar
I'm nutty for Nissans
need another bolt?
