grinding noise from rear driver's side wheel
Old Jun 15, 2005 | 07:45 PM
Stillen_I30's Avatar
As the title states, my car has developed a grinding noise from the rear driver's side wheel when the brake is depressed (such as when I arrive at a red light).
When the light turns green and i hit the gas, the grinding noise persists and then fades away after a few seconds of driving. I assume something is up with the brakes obviously, but is it that the pads are low or the rotors are done? I've had the pads replaced but not long enough ago that they should be worn out. Besides, my front pads still stop the car quite well, and no other noises are emitted from other wheels.
Please help me discern whether the noise stems from a problem with the pads, rotors, or something else (such as low brake fluid causing the pad to collapse and be held to the rotor?).
Old Jun 15, 2005 | 07:49 PM
njmodi's Avatar
Do I get a tax break?
The rear pads are past the wear material and what you are hearing is metal on metal. If the pads were replaced recently (all depends on what you consider recent), you might have a sticking caliper, which is why the pads might have worn down quicker than you would expect.
If the rotor surface has been scarred a lot, you may want to consider replacing the rotors when you replace the pads. Also make sure the caliper isn't binding - o/wise you'll have the same problem again.
Old Jun 15, 2005 | 08:27 PM
JwaxMax99's Avatar
If the pads were replaced "not too long ago" it's most likely a stuck caliper; it wears down one of the two brake pads.
Old Jun 15, 2005 | 08:52 PM
aznsap's Avatar
if its an awful grinding noise, you calipers are probably frozen and your rotors are being eaten by the more than worn down pad. in that case, you'd have to replace the rotors, calipers, pads.
Old Jun 15, 2005 | 08:54 PM
JwaxMax99's Avatar
Ya, that's worst case scenario....
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
Flores94
Aug 11, 2015 12:53 PM
erniel
Aug 8, 2015 09:32 AM
