Rotors and brake pads
Old Jun 16, 2005 | 11:49 AM
ACEEMaxima's Avatar
Hey, I'm in the process of getting a new braking system...so let me know what you have. What type of brakes and pads, and how you like them. Or what you would suggest. Thanks
Old Jun 16, 2005 | 12:31 PM
NmexMAX's Avatar
dot dot dot ...
Stock all around, it fits my needs
.. Dude your sig needs correction.
Evo w/ Wanli 253/40 tires
It should read 255 correct?
Old Jun 16, 2005 | 01:31 PM
aznstormin's Avatar
stock rotors and Bendix (sp?) pads ..i seem to have gotten a lot of brake dust in my front tires after 5 months tho.... =\
Old Jun 16, 2005 | 02:01 PM
NmexMAX's Avatar
dot dot dot ...
5 monhts... Mine get dusted in a week .. ...
Old Jun 16, 2005 | 04:48 PM
1996blackmax's Avatar
I have used Hawk HPS pads twice now and I am happy with them. Better stopping than OEM and less fade. Only thing is that you will get more brake dust.
Old Jun 16, 2005 | 09:55 PM
96_chris's Avatar
I've had both stock rotors and Axxis Metal Masters
and
Bembo Rotors and Raybestos whatevers ..
The Axxis Metal Masters worked extremely well. They would grind every now and then, but you could stop on a dime. But, they chewed the crap out of my rotors.
The Raybestos don't stop anywhere near as well as the Metal Masters. They are better than OEM, and work well. They seem quite, and don't dust bad.
I still have a soft spot for the Axxis though....
Old Jun 16, 2005 | 09:59 PM
ThisMaxIsTight's Avatar
brembo blanks and OEM pads is the way to go .. trust me ive done my brakes a few times and this is the best setup!
Old Jun 17, 2005 | 07:12 AM
SPiG's Avatar
SomePsychoGuy
http://maxmods.dyndns.org/index.php?MaximaBrakePads
http://maxmods.dyndns.org/index.php?MaximaBrakeRotors
Old Jun 17, 2005 | 11:07 AM
Dubbya's Avatar
VK56 Inside
Check my cardomain page for my setup. I am VERY happy with it.
Old Jun 19, 2005 | 10:09 AM
ACEEMaxima's Avatar
Thanks everyone. Any other suggestions
Old Jun 19, 2005 | 10:57 PM
FishyMan's Avatar
i have MM that i have yet to put in my max. i have stock rotors. what u guys mean when they EAT UP the rotors??
i still have pad life but one of these days, during summer, im just gonna do the fronts as i dont have time during the regular year. in terms of bedding them in, what method do u guys use? i find it kinda hard for me cuz of where i live. im near the city area, so having a place to go to 60 mph and what not might be tough. i was thinking of taking it to the freeway at nite or somethign.
Old Jun 19, 2005 | 11:20 PM
FishyMan's Avatar
what are the torque specs for the pad replacement?
so the shims go behind the MMs?
Old Jun 21, 2005 | 09:44 AM
CHizAD's Avatar
I just bought some Brembo Cross Drilled Rotors this weekend and now i'm trying to figure out which brake pads would be the best to go with them. I don't want to eat up the rotors since they aren't cheap. I heard OEM brake pads work pretty good compared to all the aftermarket ones.... Any suggestions???
Old Jun 21, 2005 | 12:08 PM
you dont need those cross drilled rotors .. you shoulda got blanks .. cross drilled squeak more, are more proned to cracking, and make more noise than neccesary .. see if you can exchange them for blanks .. if not .. the best pads, and I know from experience are OEM..there is VERY LITTLE dust, and what a relief since the pads I used to have made my rims gunmetal in 2 days, and im not kidding, they were axxis ultimates ... get oem pads, there is no noise from the oem if you use the shims and they stop well
Old Jun 21, 2005 | 01:10 PM
sterlingmaxima's Avatar
i reccomend getting the bendix pads cermaic ones they are 35 at advanced auto and carry a lifetime warranty now for the rear anything will do becuase the rear is barely used maybe 12 percent of braking is done back there.
Oh by the way the bendix pads are very low dusting and for the price a very good overal pad
Old Jun 21, 2005 | 01:18 PM
kingrukus's Avatar
no more maxima...
I have brembo x-drilled rotors and axis/pbr metal master pads.
The Brembo X-drilled rotors feel fine, but because they are not zinc plated, they are rusting pretty badly on the edges. My suggestion: get zinc plating, its worth the $.
The Axis/PBR Metal Master pads perform well, do not really make much noise (a very rare squealing), but they dust pretty badly (my wheels are currently covered in a layer of red dust after about 1.5 weeks).
Old Jun 21, 2005 | 01:47 PM
2 Da Max's Avatar
i have stock and i hate it, i just ordered some rotors off ebay, well im going too. think i should get them? 140 for all 4 slotted and drilled without shipping. i think its r concepts
Old Jun 21, 2005 | 02:48 PM
Brudaddy's Avatar
A good/cheap setup is as follows:
Rotors: Blanks......any brand is pretty good. Just go to the local parts store and they should be like $20 each.
Pads: I would go with the Raybestos Quietstop. They have good stopping power, but very little dust. They seem to last quite a long time, because with pretty heavy driving/braking....I have had mine for over 40k miles. They only cost like $40 too.
Old Jun 21, 2005 | 02:51 PM
maximaah's Avatar
I've got Brembo blanks for the front if you need 'em. Thought I needed to replace all 4 rotors, but only the rears, so have the fronts sitting in the garage.
Old Jun 21, 2005 | 02:53 PM
maximaah's Avatar
I wouldn't get drilled/slotted. Even on the track, drilled can only be a potential problem for cracking. Why get them for street use?
Old Jun 21, 2005 | 03:24 PM
raycer911's Avatar
I recently put zinc-plated drilled/slotted rotors (from iRotors via eBay ~$76/pair) and AXXIS Ultimate pads (front and rear ~$95/all) on my '99 Maxima. Also braided stainless/Teflon brake lines and Ate Super Blue racing fluid. They look great, don't rust, and stopping power hot or cold is really teriffic - nearly as good as my Porsche Carrera; no squealing, but brake dust is really nasty! Worst I've ever seen, whether Mintex, Raybestos, Ferodo, Performance Friction, EBC, Hawke, OEM, Jurid, Ate, Textar, -- these Axxis Ultimates stop great, but are absolutely filthy! I've run cross-drilled rotors on my Porsches for years now, including at least 4 track days per year where I enjoy being absolutely brutal on the brakes -- smoke, stink, turn the rotors blue -- but no cracks from the rotor holes. Yeah, I've heard that it can be a POTENTIAL problem, but in my experience, only for hard-core racers, not with hard-driven street cars.
Old Jun 21, 2005 | 04:02 PM
Brudaddy's Avatar
I have heard of lots of slotted rotor cracking in hard-driven street cars.
Old Jun 21, 2005 | 06:18 PM
konak85's Avatar
If you don't want mad brake dust and rust on your rotors, don't get cheap brake parts like the autozone type.
Old Jun 21, 2005 | 06:32 PM
Mrbizness1's Avatar
Where can you get rotors for $20 each? I paid about $50+ for rabestos at pepboys, unless you buying the thin ones which can't be cut.
Old Jun 21, 2005 | 07:23 PM
TsingTsaoNYC's Avatar
Best pads for stock, Porterfield R4S (they dust alot though)
I like the Brembo blanks.
Remember, you get what you pay for
Old Jun 21, 2005 | 07:41 PM
FishyMan's Avatar
u know the axis pads, it comes in the metal part. wa/ the backing and gold clip thingy. whts that part called? teh shoe?
i still need to use back the OE shims right?
anyhow anybody know the toruqe specs on the calibeer bolts/
Old Jun 22, 2005 | 02:31 AM
J_Nuggz's Avatar
brebro is the way to go rotor wise, i went aem big and they wernt too bad but the did chew up the rotor
Old Jun 22, 2005 | 04:50 AM
maximaah's Avatar
huh?
(arbitrary typing at bottom of post to meet limit on number of characters. Not that there aren't a lot of characters on this board.)
Old Jun 22, 2005 | 03:22 PM
Brudaddy's Avatar
The dust comes from that pads....not the rotors.
I was saying get the cheaper rotors and then get good pads.
It is a good setup....I have been running them for a while.
Old Jun 22, 2005 | 05:07 PM
aznsap's Avatar
i have brembo zinc plated rotors all around. if you have rims i would suggest these so no ugly rust is visible on the rotors
Old Jun 23, 2005 | 10:36 PM
FishyMan's Avatar
where did u get them quoted? can u ask them to coat for u?
can u guys explain brake pads and shim??
im getting AXIS pads and the pads have this plastic backing w/ the metal connectors to it. exactly what is a shim?? i mean it goes behind the pads backing right?
are raybestos the same?
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
