Hard starts...
Hard starts...
The longer the car sits after it's prior drive, the harder it is to start. I've read somewhere that there is a sensor that reads a temperature (engine or outside maybe?) and tells the ECU so the ECU knows how much fuel to give. Anyone know anything about this?
I have to pump the gas quite a bit to get her to start.
Engine coolant temperature sensor.
Pumping the gas prior to a start up on a fuel injected engine does absolutely nothing.
You could also have a defective cold idle plunger. A Haynes shop manual will help you troubleshoot your car.
It's a wise investment.
Hard Starts Also!
I have an interesting problem now:
Crank forever when cold with no codes. Runs very well once started. The problem first manifested with a complete inability to crank - no solenoid operation. Sounded like the relays were making up but no solenoid coil pickup. I put my hand down under the solenoid to feel for a loose connection and returned to the driver's seat and it started fine. Got home, removed the starter, checked it out, reinstalled the starter and then the continuous crank began. Eventually can start the engine with the acc. pedal depressed to the floor. No smelll of excess gas though - it doesn't seeem flooded. This is what i have checked so far:
Crankshaft position sensor (POS) rear flywheel - found it to be defective - replaced with a new one tested in the harness and it worked properly - and it had no effect but to give me two codes - air temp and knock - both of which could not prevent a start - may have done this during the replacement
Camshaft Position Sensor - checked wiring and ECU terminals for continuity - all sat - resistance in specs
Crankshaft position sensor - (REF) cheched wiring harness to ECM and resistance of unit - all Sat
IACV removed, cleaned, tested IACV - it moved in and out with the ignition switch as predicted - you can see the stepdown of the valve when the engine starts - fron 1200 to 100, to 800 as the engine warms.
So, as you can suspect, I am stumped - I think the problem is a malfunction in the simultaneous fuel injection mode and I can't figure out what triggers this response. However, one perplexing situation does exist - I need to figure out why, when I reached in and grabbed the wiring in the starter area did the engine then crank? Is there a wire broken somewhere?
By the way, I broke down and brought the car to the dealer today - after reading the codes (the two i mentioned before) they told me there is an electrical problem and $2500.00 plus a new wiring harness would solve the problem - hat ever happened to troubleshooting!
Thanks for any help you can offer.
Mike
Mike
try to start it with clear flood mode. foot to the floor on the accelerator pedal, and turn the car on.
couple of things factor into the a/f ratio on start up
1)CTS
2)MAP
3)MAF
4)TPS
btw, whats your fuel pressures at? static and at idle.
Try spraying a bunch of carb cleaner into the intake manifold... If it starts up instantly, you know you have a fuel delivery problem as the carb cleaner acts as instant fuel.
I am dealing with the same thing you are... I have tried anything and everything. I noticed that it starts up like a dream when I spray carb cleaner into the manifold so I tested the fuel pressure and found out that in the on position, I have 0 psi where I should have 43 psi... this explians the hard starting.
I'll try to the throttle body cleaner trick though...
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
