Replacing the rear oil seal
The Factory service manual (FSM) says you need to remove the oil pan to do this. Is this really necessary? Can you replace it without removing the pan? Also do I need to use a liquid gasket like brought out in the FSM? Thanks
To replace the rear main oil seal retainer (the metal part)...NO
To replace the rear oil pan seal that sits below the rear main oil seal retainer (the c shaped rubber seal)...MAYBE. It has been done with out removing the pan, but it can be a b!tch. Just ask DR-Max.
Put liquid gasket on both...YES! ALWAYS YES!!
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
maxinout93
Aug 20, 2015 02:17 AM
