A/C specifications?
Old Jun 18, 2005 | 12:48 PM
quaker's Avatar
A/C specifications?
I borrowed a manifold set to check the high and low side of me a/c system. The readings I got were about 30 psi low side and 210-250 psi high side.
My question is are these numbers within specs?
The a/c seems to work fine but it will be getting very hot here soon so I want to get a jump on any problems. I added a can of 134 a few weeks ago as it did not feel all that cool.
Old Jun 18, 2005 | 01:34 PM
joeeey's Avatar
It's gonna depend on the outside temp.
Old Jun 18, 2005 | 01:48 PM
njmaxseltd's Avatar
Exactly, but those numbers look just fine.
Old Jun 18, 2005 | 06:54 PM
quaker's Avatar
Outside temp was about 100 degrees.
I vacuumed the system this afternoon for an hour and she held pressure for 1/2 hour after that, so I think I dont have any leaks. I did this because a friend had a vacuum pump and I figured after 10 years it could be a good thing for the system.
I will be recharging in the A.M. with (2) cans of r-134 and (1) can on 2oz ester oil when the temps will be around 75-80. I read the a/c system holds between 21-25oz of refridgerent. Anybody see any problems with this?
Any suggestions?
any and all informed suggestions welcome. Thanks
Old Jun 20, 2005 | 02:25 PM
quaker's Avatar
Are the readings from the high side dependent on the outside air temp?
Old Jun 20, 2005 | 06:10 PM
joeeey's Avatar
High and low but more so on the high side. @ 100 degrees 200 to 250 sounds fine. Correct me if I'm wrong but isn't 16oz = 1 lbs. If so 2 cans would be 32oz way too much.
Old Jun 20, 2005 | 06:14 PM
njmaxseltd's Avatar
Joeey is correct, 2 cans will be to much. 1 - 1/2 is plenty of R134 for our cars A/C system. If you over charge it, your A/C will not work with it's very hot outside, but might work fine at cooler temps.
Old Jun 21, 2005 | 08:41 AM
quaker's Avatar
After charging the system the low side reading was 35-40psi and the high side showed 240-260psi. Actually the cans I used were 12 oz each plus the 2oz oil charge. I read that the system holds between 21-25ozs. In that event I might overcharged a bit, but yesterday it was 110º at 5pm and the a/c felt nice and cold. .
Old Jun 21, 2005 | 11:35 AM
dharrison's Avatar
I have another question... my AC is blowing the temp of the outside air so I figured that it needed a charge. So I charged it up to about 35 psi and it still wasn't blowing cool. I think that it may be my compressor?
What else could it be?
Old Jun 21, 2005 | 01:48 PM
dmplus's Avatar
Same problem here. I know the clutch for the compressor kicks on cause i can hear it. Someone told me there is a pressure valve that regulates the pressure that may be stuck or malfunctioning. I dont know enough to say wether that's right or not.
Old Jun 21, 2005 | 02:30 PM
BlackMazi's Avatar
Same here, when i had my AC charged yesterday, the mechanic told me I have a sticky valve. I get cool air but not cold. It's only cool when the outside temperature is cool. Any idea?
Old Jun 22, 2005 | 12:04 PM
jaemax's Avatar
where is this so called valve located because I think I am having the same problem. The tubing from the compressor is getting cold but after the connection, the tubing thereafter is not cooling. I am guessing that the valve is at this connection? Let me know... it is getting hot here and I am dying of the heat and the leather... can you say.... WETBACK!!!! no pun intended...
jae
Old Jun 22, 2005 | 01:02 PM
dmplus's Avatar
I'm not sure where the valve is, but apparently it's a common problem. Mechanic quoted me like 125 bucks to fix, so i'm guessing it's not that expensive either.
Old Jun 22, 2005 | 01:22 PM
BlackMazi's Avatar
MY mechanic told me $400... looks like i need to look else where
bigdogsteve
Jan 31, 2018 04:18 PM
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
