is Tranny cooler supposed to feel "to hot to touch" at idle?
Old Jun 18, 2005 | 05:53 PM
nick's Avatar
Guys - is your auto tranny cooler pretty darn hot when car is at idle?
Today I've installed B&M auto tranny cooler , everything went pretty smooth
once everything was assembled , I've started the engine to check for leaks
well , there was none , but once the engine got up to operating temperature
tranny cooler was pretty darn hot as well, I think this is normal , but i just need somebody to confirm that this is normal.
This is how I've hooked things up: I 've removed transmission return line (upper one , without bonjo fitting) , than ran inlet hose from B&M tranny cooler to inlet port on the radiator and, outlet line from B&M tranny cooler back to transmission return port.
thanks
Nick.
Old Jun 18, 2005 | 06:05 PM
madnut's Avatar
All i know is that the manual tranny gets pritty hot, and stays hot longer then the engine
Old Jun 19, 2005 | 02:47 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
its normal because there is heat transfer through those fins. if its hot, then its doing its job.
Steve
Old Jun 19, 2005 | 08:07 PM
texasmax's Avatar
Yup. If it's not hot, you've got a problem.
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
catalinvint
Sep 16, 2015 07:48 PM
