where my check engine light go?
Old Jun 19, 2005 | 06:15 AM
maximavqpower97's Avatar
I turn on my car thise mourning always expecting the check engine light to be on.i never reseted the ecu but now the check engine light has dissapeard so is the problem fixed ?
Old Jun 19, 2005 | 06:18 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
bulb is burned out
Old Jun 19, 2005 | 06:43 AM
cant be this car never had a check engine light it has only been 2 weeks
Old Jun 19, 2005 | 07:38 AM
udienow's Avatar
... That doesnt mean the bulb has burnt out... I had the light on and after some time it went away itself. I assumed the problem fixed itself. Then I put in my intake and now it is back on again, so it didnt go out because it burnt out in my case.
Old Jun 19, 2005 | 08:52 AM
Sy0p's Avatar
my check engine light has been on for the past 2 years untill 2 days ago when i finally fixed all the problems all i have to do is get synthetic oil change and do a tranny flush ( i have metal in my trans fluid) take it to the track and hopefully i run mid 13's
Old Jun 19, 2005 | 03:38 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
after so many restarts. if the problem is fixed, the cel will go away. most times its just 3-4 restarts.
Old Jun 19, 2005 | 03:54 PM
Oh thats good news kill crap... but i turn it on like 15 times already.
Old Jun 19, 2005 | 04:20 PM
Bill73083's Avatar
My CEL turns on every time some major work gets done on the car, especially when I used to bring it to the stealership. It usually went away after a few weeks. I think it might just be that the sensors are extra sensative, sometimes.
Old Jun 19, 2005 | 09:01 PM
TurTLe*'s Avatar
no the reason why your CEL goes away because some codes use a 2 trip cycle and other types of cycles. Like you can start up your car and have a problem but CEL wont turn on. Turn it off and let the car sit for a while and then turn the car back on and if the same problem is detected then the CEL will turn on. After about 100 cycles if the problem doesn't show up anymore the CEL will go away.
By cycle i dont mean turn on and off instantly. But more like drive around let the engine warm up and then let it cool down. Most likely a typical person needs about 2-3 months to go thru 100 drive cycles.
Not all CEL are 2 cycles, some are 1 cycle ( which is instantly) then are some other types as well.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
