Camber issues
Old Jun 20, 2005 | 05:58 AM
ejj's Avatar
ejj
Camber issues
I have H&R springs and newly installed factory struts. Love the look and love the ride! I also have Stillen Camber plates. One of the things I really want to correct the the massive amount of negative camber that my car has had in the past. I'd only get 10k miles on a set of tires, 'cause the front of the car would tear the up so quickly.
I've taken as much camber out of the front as I can with the plates, and I can still visually see that there is too much negative camber. I haven't had an alignment done yet, but there isn't any other adjustment.
Is this normal with H&R springs? Other options? I shouldn't _need_ both camber plates and bolts, should I?
Old Jun 20, 2005 | 08:18 AM
ThisMaxIsTight's Avatar
ummm dude get an alignment .. thats all I can say
Old Jun 20, 2005 | 08:21 AM
ejj's Avatar
ejj
...and that would help my camber problem how?
Old Jun 20, 2005 | 08:39 AM
gtr_rider's Avatar
192.168.1.1
the tires being eaten so quickly is the toe in the alignment..
Old Jun 20, 2005 | 09:35 AM
gabex's Avatar
..that's the first thing I would consider fixing.. the stock suspension isn't designed to be used with firmer, shorter springs.
Old Jun 20, 2005 | 10:38 AM
alphaerror's Avatar
yea, agreed with gabex... dont use stock springs with aftermarket shocks or vice versa. and an alingment prolly wont hurt...
Old Jun 20, 2005 | 03:02 PM
tbergma1's Avatar
camber issues
I put on tokico's spring shock set (HPK245) on my maxima. I also bought the eibach camber bolts. My car was lowered about 1.5" and my camber is Left -.8 and right is -.6 specs call for .4 to .8 on negative camber.
Make sure the f**ken mechanic tightens up the jam nut on the tie-rod end. I also would suggest replacing the strut mount bearings.
the other guy is right, my toe in was really off like 3°
Old Jun 20, 2005 | 09:20 PM
BEJAY1's Avatar
Conecarver
Agreed - align that toe. I'm running -2.5" camber on the street and it's not wearing the tires nearly as much as the +1/4" total toe out is.
Old Jun 21, 2005 | 04:37 AM
njmaxseltd's Avatar
Absolutely correct!
When you lower a Maxima the toe, which should be slightly inwards goes way outward. It's not a camber issue thats causing your tires to ware out, it's the front toe. Have the car aligned, tell the tech what degree camber you'd like to run with so he can set up your camber plates.
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
