gear oil?
Old Jun 21, 2005 | 11:42 AM
Laly's Avatar
gear oil?
i have to put new gear oil in since i popped my axle out on accident. i have been ordering redline shockproof for my se-r. its gl-4. can i use the same in the maxima. what do you guys recommend. i have a 97 5 speed maxima. thanks.
also, should i replace my axle seal. i didnt, but the car is still up i can still replace it. all i did was pop te axle out and pop it back in. thanks
joshua
Old Jun 21, 2005 | 11:59 AM
Bobo's Avatar
I'm not sure what redline shockproof is, but have certainly heard of redline. Use only GL4 in your 97 Maxima, do not use GL5 or any GL4/GL5 blends. I would be inclined to replace the axles seals. What condition are the CV boots in?
Old Jun 21, 2005 | 12:41 PM
Maximeltman's Avatar
just use redline mt90
Old Jun 21, 2005 | 12:45 PM
Laly's Avatar
boots are fine. im going to leave the seal in if it leaks, then i will change it. i just put down the front end, im working on the rear now. thanks. i will order soem mt90.
Old Jun 21, 2005 | 08:17 PM
Laly's Avatar
how do i fill the tranny with the fluid. i took all the intake stuff off to look for it. is it the bolt that looks like you need to put a rachet in there? i thought that was it but i didnt take it out because its on the side of the tranny housing. i thought that it would leak out. all i need to do i fill my tranny up and ill be ready to test my coilovers. thanks
joshua
never mind, i found it.
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
