6spd MT Swap
6spd MT Swap
Is it possible to swap in the FWD 6spd transmission into a 4th gen? I assume it's possible with little modification since the VQ35 and VQ30 have the same outer mold. Apparently the shop who rebuilt my 5spd did a **** *** job and I wondering if this is a viable option. Any help is appreciated. Thanks.
-Dexter
The reason I ask is because I'm looking to go to the VQ35 anyway, and I'd sooner do it all at once. Obviously the tranny will attach to the block with no problem, but my worry is mounting points for the tranny, fitment and driveaxles. Also is the 6spd VSLD? If it's not then I guess it's really not worth the hassle and I should just get an AE tranny.
Originally Posted by soontomaxima
At highway speeds would you be able to save a lot of gas with the extra gear?
I was under the impression that the final gear ratios of both the 5-speed and the 6-speed were very similar, with similar fuel economy numbers. The 6 speed is a closer ratio tranny, with the gears closer together than in the 5-speed. Not entirely sure though, the 6 speed could be a little better, since it has the same fuel economy when paired with the 3.5 as the 5-speed with the 3.0
Originally Posted by THT
IMO, a 6spd is not worth it as you will have more drivetrain loss.
The 6-speed is not VLSD. It had an optional HLSD (Helical Limited Slip Diff.) which a lot say is actually a better form of LSD. I can't speak from experience or technical knowledge, though.
Originally Posted by Tatanko
Why? Show me proof to back up that statement, please.
If you're going with a VQ35, then I'd say go for it. Again, though, I'm not sure how much custom work is going to need to be done.
Intuition says more moving parts results in more loss.
I seriously doubt an extra gear will make a huge difference in the power to the wheels. Perhaps if I had any interest in drag racing and the like it would bother me but this is my daily driver and I'm just looking to have more fun with it.
I'm sure the 6 speed is slightly heavier, I thought that the 6th gear in the 6 spd trans was just an extra gear they through in there that was taller than the 5th gear in the old trans, that allowed the car to idle lower at higher speeds. This was the main reason that the car isnt that much faster as a 6 speed compared to the automatic (5.5 gen +)
Originally Posted by 2 Da Max
keep it 5spd, i doubt our motor can handle all of it... unless your car has alot of power and then maybe you would benefit from it.
6-speed manual w/OD
Specifications
Transmission gear ratio (1st) 3.15
Transmission gear ratio (2nd) 1.94
Transmission gear ratio (3rd) 1.39
Transmission gear ratio (4th) 1.06
Transmission gear ratio (5th) .81
Transmission gear ratio (6th) .63
Transmission gear ratio (reverse) 3.00
Final Drive ratio 3.81 or 3.79
5-speed manual w/OD
Specifications
Transmission gear ratio (1st) 3.29
Transmission gear ratio (2nd) 1.85
Transmission gear ratio (3rd) 1.27
Transmission gear ratio (4th) .95
Transmission gear ratio (5th) .80
Transmission gear ratio (reverse) 3.43
Final Drive ratio 3.82
As you can see from the Info here the Ratios are very similar across the board and 6th gear is far taller in then the 5th in the 5spd. Not only can the VQ30 handle the 6spd you will basically only get better fuel milage from the addtion of a 6th gear. However the 3.0 may not have enough torque to over come some hills while in 6th.
Specifications
5-speed manual w/OD
Specifications
Yeah I took my baby up Pikes Peak yesterday and was running in 1st and 2nd almost the whole way. When I got up to about 12,000ft she was hurting bad. Not too sure if it's a problem with ym synchros but I have to be almost completely stopped to get into 1st, guess I'll just order the transmission after I get some cash for my birthday.
I have them plotted at work of course, how convienient, with speed with respect to MPH, and the 6 speed wont be worth it in the end. And when people say it's only moving one gear at a time, it's not as they are all conncected, but the current gear is spinning that particular gear ring at that time, though they are all spinning. And the 6 speed has a heavy **** flywheel. These are the reasons that the Sentr SE-r and the 6 speed Maxima have low dyno #'s comapred to their automatic counterparts(Maxima in specific). Stick with the 5 speed, the 6 speed is essentiall a double overdrive system, with the only gains slitly at about 80+, but even then you have to shift one more time which will cancel out any distanced gained. The 5 speed actually is more agressive surprisingly enough. Also the fuel economy is not that much better when compared to the 5 speed.
Originally Posted by Christobal65
what you dont have freeways that go throuh mountains where you live?
As for the weight of the flywheel I'm going to put a Fidanza or JWT flywheel on when i do the engine swap, I figure might as well do it while it's out of the car, and as far as speed is concerned I'm doing 80mph+ on the highway almost all the time here, which is a majority of my driving. Right now with the 5spd my engine is running 3300-3500rpm while doing 80-85mph, if I could I would just replace the 5th gear on mine with the taller 6th seeing as the only reason i really want it is for better gas mileage at high speeds. 4th is fine for up to 140mph anyway and I've only done that once before anyway.
Yeah...I can't see why it would kill anyone to downshift to 5th though.
I guess my point is that gearing is very tricky and can effect your cars in many ways some good and some bad
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
