High Idle
Old Jun 25, 2005 | 04:49 AM
speed racer's Avatar
High Idle
Recently I installed a hyper grounding kit. Before installation the engine would idle under no load aroun 700 -750 RPM now its idling around 800-850 RPM. I also noticed that my car has been guzzling a little more gas lately since I done this. Would a high engine idle lower my MPG? I also tried to adjust the idle speed screw on the IACV but the damn thing won't budge What can I do?
Old Jun 25, 2005 | 05:42 AM
BigLou93SE's Avatar
This is funny...I actually seem to be getting worse gas mileage with the hyper grounding kit that I bought also, however I haven't seen an increase in idle speed. Has anyone else's gas mileage gone down after installing these wires?
Old Jun 25, 2005 | 06:10 AM
happyricefob's Avatar
V^___^V
at cold start the idle would be higher. after the car is well warmed up it'll drop down a little. high-idle does not make obvious MPG difference. i wouldn't trip...
Old Jun 25, 2005 | 08:47 AM
I was able to turn the idle screw on the IACV this morning when the engine was first started with some needle nose pliers. However, after driving it around a bit and trying to turn the screw it is nearly impossible. I guess b/c the engine is hot. I also checked my codes and there's nothing wrong. I'm going to try to drive on a tank of gas and hope that the hyper grounding kit is not making me lose any gas, which I find hard to believe.
Old Jun 25, 2005 | 08:51 AM
Chief Brody's Avatar
I don't think the screw not turning has to do with the engine being hot. It just stops after a while and I haven't found you can do must adjusting with it anyway. Just be careful because it is plastic. Hope you find the problem soon.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
