For People with SPRINT Springs or Some knowledge
Old Jun 25, 2005 | 08:16 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
Ok I installed these Sprint springs and I got Aligment and now I have alittle Vibration when accelerating and body with these spring experience this issue.
Here is my Suspension setup
KYB AGXs
Sprint Springs
19"inch Rims wrapped with BFGoodrich KDW2 size 225-35-19
I also fixed both Staberlizer Links and Inner and Outter Tire Rods.
I'm thinking that the Drop is probably just too low I don't know any suggestion what it could be.
Old Jun 25, 2005 | 08:22 AM
RastaManMax's Avatar
KYB AGXs
Sprint Springs
I also fitted both Staberlizer Links and Inner and Outter Tire Rods.
I thinking that the Drop is projust too lowI don't know any suggestings what it could be.
Posting the spec sheet from your alignment might help. I got vibrations when i put on my 18's but that was because they weren't in balance. When was the last time you had a balance done? Does the vibration come only when accelerating or when just staying at a constant speed as well? More info on the vibration would be helpful.
LEMAR
Old Jun 25, 2005 | 10:46 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
Cool I will do that as far as posting specs but I only get the Viberation when I begin accelerating. only around 15MPH theres viberation after that i'm Fine.
Old Jun 26, 2005 | 11:35 AM
DAVE Sz's Avatar
Hooooooonda.....
You need camber bolts or plates. The tires are way to narrow and the profile seems very low as well.
Old Jun 26, 2005 | 11:40 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
I have the Eibach Camber Kit On there maybe it has to be adjusted?
Old Jun 26, 2005 | 11:42 AM
MAXDADDY98's Avatar
Maxima.Org Bishes
And Welcome back Dave I like new name The Antagoniz0r
Old Jun 27, 2005 | 04:42 PM
99Maxxx's Avatar
I'm gunna agree with dave on that one....I've got Sprint and 17x8 Konigs and have no alignment problems with the stock setup
Old Jun 27, 2005 | 04:51 PM
|Bijan|'s Avatar
UCF Lexus
I took my car to get aligned, turned out I had a broken camber bolt. But vibration might be the balance of the wheels also...
Old Jun 27, 2005 | 06:07 PM
MaximaSE96's Avatar
Maxima Owner
had sprints on old maxima...not a problem with vibrations...check ur tire pressure and might want to have them rebalanced as well
BobTX10
Oct 7, 2015 08:43 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Marc2theMax
Sep 28, 2015 08:13 AM
REDinLV
Sep 28, 2015 12:31 AM
Tmax78
Sep 25, 2015 09:07 PM
