ECU code 0111
Oh well... I have a service engine light soon. Code 0111 -
EVAP/Flow problem.
Can someone tell me where the EVAP canister is? I would also like to know which hose/tube to check for proper connection. Are there anything else connected for associated to this problem?
Thanks!
Vic
EVAP/Flow problem.
Thanks!
Vic
DTC 0111
EVAP/Flow problem.
Thanks!
Vic
EVAP/Flow problem.
Thanks!
Vic
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless. It may be accompanied by another DTC which is more specific.
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
