Is there a seperate wire on the socket for high beams?
Old May 19, 2001 | 08:51 PM
Nick Robinson's Avatar
Hey,
My headlight socket burnt out a while ago, so today i was crimping it on (i used tape before, heheh, too lazy and it was cold out). Anyway, i got all of them crimped except one, because the wire was way to short, so i just left it. I put in new bulbs too, so i was just checking to see if the bulb on the other side worked. Well both lights turned on. High beams on the side with the one wire off doesnt work, so is that wire just for high beams? Is it ok to run without that wire connected?
thanks
Old May 20, 2001 | 08:23 AM
Enduro's Avatar
Originally posted by Nick Robinson
Hey,
thanks
I think that unconnected short wire is the one that provide power for high beam. Awhile ago I was fooling around with the socket by connecting a wire from one of the socket's 3 connector to ground, and another connector to power and got low beam. I then switched the wire for power to the other connector and got high beam. From that experiment I concluded that the three socket connectors are for ground, low, and high beam. You should be ok with that high beam wire left unconnected.
Old May 20, 2001 | 09:47 PM
dch95's Avatar
Naked wires..
Hey,
thanks
One wire is the ground, one is the low beam and the other high beam. If the wire from the car side touches bare metal, you will blow a fuse so tape it up or figit
Old May 21, 2001 | 01:27 AM
vmok's Avatar
how did you burn out the headlight socket? just wondering.
-V
Old May 21, 2001 | 04:05 AM
-V
I burnt it using 80 watt bulbs =)
Old May 21, 2001 | 11:47 AM
vmok's Avatar
haha.. i hear you... that happened in one of my other cars... never put in high wattage bulbs again....
in my other car, the bulb shattered inside the housing, melting part of the lense, the connectors were fried/burnt/crisp, and it blew out the high beam swich on the steering column...
-V
Old May 21, 2001 | 02:21 PM
-V
Damn!! I got free replacments when the burnt so i just put them back in, hehe.
DJLAX152
May 4, 2021 11:46 AM
AaronL
Nov 15, 2020 11:52 AM
Maxima.KsA
May 15, 2020 04:14 PM
