Replacing Rear O2 sensor
Old Jul 5, 2005 | 09:37 AM
AxisKill's Avatar
only writeup i can find is:
http://www.motorvate.ca/mvp.php/509
doesn't say what tools are needed etc..
i just got my rear o2 sensor in the mail (and id like to replace it asap) but im tool-less (i may have a phillips around here) atm .. does anyone know / remember whats needed to get the o2 out / in? is it plug and play?
i don't feel like jacking the car up with the max-jack and seeing that there's nothing i can do besides twist with my teeth.
Old Jul 5, 2005 | 09:53 AM
wikidminds's Avatar
ur screwdriver is useless for o2 sensor removal. go to ur local auto parts store....ie:advance auto parts....and take the o2 sensor wit u.
ask em where the sockets are to remove o2 sensors.
they come in diff sizes. buy the right size socket. these sockets have an opening on the side so that thee wire from the o2 sensor wudnt get in the way.
also buy a ratchet to fit ur socket for the o2 sensor.
Old Jul 5, 2005 | 10:28 AM
DragonMaxima's Avatar
You can also rent tools from Auto-Zone if you have one near you.
Old Jul 5, 2005 | 11:13 AM
86maxima96's Avatar
I Broke OT
an O2 socket whould be all you need. it's a tight fit if you still have the stock y-pipe.
Old Jul 5, 2005 | 11:15 AM
Black Maxima
I used an adjustable wrench on all three of the my o2 sensors...
Old Jul 5, 2005 | 11:28 AM
vqmax
the cheapest and easiest way is just a 22mm open end wrench..itll set you back like..2 dollars. get a cheap *** one.
Old Jul 5, 2005 | 11:31 AM
Chickan's Avatar
yeah opened ended wrenches work. I had to use one on one of my front O2 sensors that I couldn't get my o2 tool in there. Also, if you just got the sensor without a plug (universal), you'll need something to attach the wires together, wire connectors + heat shrink work nicely.
Old Jul 5, 2005 | 01:05 PM
f550maranello2's Avatar
dude go to autozone and get the tool its free to rent... all you need is a 1/2in drive ratchet... thats all
Old Jul 5, 2005 | 03:12 PM
vqmax
or walmart for a 2 dollar wrench, save some gas money. wont have to take it back.
Old Jul 5, 2005 | 03:54 PM
kosmo886's Avatar
open end wrench should work...or an 02 socket, i replaced my front o2 sensor a few weeks ago and that was a real pain, the rear should be much easier as long as rust isnt too much of an issue it should be pretty much plug and play. just dont touch the tip of the sensor
Old Jul 5, 2005 | 09:40 PM
AxisKill's Avatar
k i did it.. expected a 10 minute job .. took 2 people a bit under an hour... the whole friggin catback is rusted to sh*t...cut off all the wiring with a knife.. then beat the crap out of the actual sensor and still nothing.. then started taking chunks out of it and finally got in a drill to finally fit with like a 7/8 socket (didn't have 22mm although i think a 20 would fit) and then got the **** out and threw it down the block.. chased it and beat it to the ground some...
then the rest was relatively easy..
CEL was gone for about 15 minutes.. which were one of the happiest 15 minutes of my maxima owning life..and then it lit back up again with an 0505 code which is what i had in the first place months ago and there's been to much maintenance done since then to list..
basically g*d is f*cking with me
Old Jul 5, 2005 | 09:54 PM
FishyMan's Avatar
what the 0505 code?? i have the 0707 and i believe its the rear. im gonna replace mines.. mines came up 2 times even after reset.
Old Jul 5, 2005 | 10:04 PM
theANSWER's Avatar
btw, how much was that o2 sensor?
my CEL is on right now and my mechanic says it's the o2 sensor, $250 (parts and labor) installed he says...at that price i feel like doing it myself
Old Jul 5, 2005 | 10:15 PM
AxisKill's Avatar
Punch your mechanic in the head ;-).
Jk.. but if you're on a budget like i was.. then man i have some good news for you
http://forums.maxima.org/showthread.php?t=289189
^ click that link.. the group deal should still be going on.. give the guys a call.
From what i was told they're only doing the "special" on "Walker" models.
it's 10% off orders by credit card over the phone, or 15% off ordered by money order (i did money order). Just mention the "Maxima.org discount" and they'll know what you're talking about.
you didn't mention whether you need a rear or front o2 sensor.. but they should have both on sale.
also shipping is free if the order is over 50$ (and it comes out to be a bit over that.. so basically you're set)
- good luck.. if you have some issues with install and its the rear o2 feel free to PM me.
Old Jul 19, 2005 | 10:37 AM
wahoohead's Avatar
17 mm open end wrench
I just did mine an hour ago. That is all it took along with some liquid wrench.
Old Jul 28, 2005 | 01:33 PM
jiminva's Avatar
I need to replace my rear O2 sensor too. I see in this thread that both 22 mm and 17 mm are mentioned. Mine is 17 mm and none of the auto parts stores had anything that size. I think Wahoohead, you said that you got yours off with the 17 mm open wrench - did you have to remove the cat heat sheild first? Thanks.
Old Jul 28, 2005 | 01:47 PM
wahoohead's Avatar
Yup
Took off the cat's heat shield, (4-6 bolts) and then a 17 MM wrench fits on there with plenty of room to spare. This was an easy job.
Old Jul 28, 2005 | 01:50 PM
86maxima96's Avatar
I Broke OT
from this GD, or whenever you order an O2 sensor, does it come with the wiring/harness to be a direct replacement, or do you need to splice the wires some?
to make it clear, are they car-specific or just unversal?
Old Jul 28, 2005 | 02:23 PM
jiminva's Avatar
Thanks Wahoohead. Those bolts are pretty rusted but I'll give it a try.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
