Should i get Stillen Hi flow intake or Injen CAI ?
Old Jul 5, 2005 | 06:55 PM
white97gxe's Avatar
Which one should i get? I dont want to cut a hold in my car so these are the 2 i narrowed it down to. Does one have better gains then the other? Thanks
Old Jul 5, 2005 | 08:45 PM
RA030726's Avatar
I'm nutty for Nissans
stillen hands down. the injen is to close to the radiator and just SUCKS hot air.
Old Jul 5, 2005 | 08:46 PM
vqmax
<----recent convert to believing that the stock intake is the way to go
Old Jul 5, 2005 | 08:51 PM
Subzero's Avatar
get a place racing cold air intake. Its the best you get the cool air outside the engine bay. Factory and the ones under the hood suck hot air in= loss of power. True cold air intakes have up to 45 degrees cooler air on hot days=more power!!!
Old Jul 5, 2005 | 08:56 PM
PoKKi's Avatar
Well recent statements indicated that you shouldn't even get a K&N filter if you stick with stock intake. But if you insist on an aftermarket intake...Stillen is more convienent...And in case there's a flood, your car won't get messed up as easily.
Old Jul 5, 2005 | 09:23 PM
Nissan 6's Avatar
stock airbox with HKS air filter http://www.2kracing.com/product_info...9a3eb4e45d8494
Old Jul 5, 2005 | 10:16 PM
VIP Maxima
hack the stock airbox, if ur looking for performance, u dont want an intake, trust me
Old Jul 5, 2005 | 10:35 PM
NmexMAX's Avatar
dot dot dot ...
Anything but Injen .. stock/hacked/Stillen > Injen
Old Jul 5, 2005 | 11:08 PM
zander's Avatar
Since hacking is the most popular thing it seems, where do you hack it? I would figure on the driver's side, the side closest to the side wall. But that area is pretty small, I have seen a hacked air box a while back with an intake funnel that seemed to head around the battery.
Old Jul 5, 2005 | 11:52 PM
mindlessoath's Avatar
here is some info on the injen
http://www.customenterprise.com/view.../vts/design017
it doesnt look that bad, however it looks like its going to recycle the hot air from the car to the pipe... good thing is that its a cold air intake meaning the pipe should ram the air in quite nicly regardless how hot it is.
i like the stillen much better, but i wanted to try this injen one... not going to tho
here is the link to the hacked airbox
http://forums.maxima.org/showthread.php?t=181899
here is annother link to HACKED AIRBOX WRITE UP**
http://maxima.cardomain.com/ride/370660/7
that may help alot the hacked airbox... cause some people just like it, and it may do some simular gains.
Old Jul 6, 2005 | 04:27 AM
white97gxe's Avatar
I hear that the only thing a hacked airbox does is make noise.
Old Jul 6, 2005 | 06:15 AM
NmexMAX's Avatar
dot dot dot ...
Thats what ANY intake does .
Old Jul 6, 2005 | 10:05 AM
yes, all intakes other than stock will make more noise. anyways thats what seems to happen.
more air will increase some kind of performance some where.
wheather it be just giving more breath to the car (instead of running out) or at certain RPM's.
some will take in hot air or some cold air, colder the better... if you are in hot air theirs ways to combat it, tho its not easy.
there are usually benifits to a modification, cause in theory "MORE AIR IN = MORE PERFORMANCE" so if you hacked something and its not improving then you probably did a half baked job at it and need to re-work/re-think it.
Old Jul 6, 2005 | 10:29 AM
cefiro8701's Avatar
the only thing injen is good for is its CARB number.
Old Jul 6, 2005 | 03:09 PM
THT's Avatar
THT
Throbbing member
Keep the stock airbox for the best combination of throttle response and power.
Old Jul 7, 2005 | 09:54 AM
99grnmaxgxe's Avatar
I bought a filter/adapter kit for my car and noticed that there was no performance and only a better sounding intake. I even lost some low end power!!!
Old Jul 7, 2005 | 10:22 AM
sdoherty_tjm's Avatar
i say go with the stillen
Old Jul 7, 2005 | 10:39 AM
d00df00d's Avatar
Old enuf to pick his own gears
@ stock intake...
Old Jul 7, 2005 | 11:08 AM
4x4Max's Avatar
Originally Posted by d00df00d
@ stock intake...
10char
Old Jul 7, 2005 | 01:18 PM
BK1's Avatar
BK1
Hello
Stick with the stock box.
Old Jul 7, 2005 | 02:06 PM
max2max-98se's Avatar
In Maxima We Trust
like every1 said stay away from injen.it was a waste of money and you lose power.
Old Jul 7, 2005 | 02:09 PM
Turbo1er's Avatar
Doin' it 4 da shorteez
If you want a CAI, get an Ebay one and just get a better filter.
Old Jul 7, 2005 | 02:11 PM
sonicrunch's Avatar
stock goddammit
Old Jul 7, 2005 | 02:12 PM
Turbo1er's Avatar
Originally Posted by sonicrunch
stock goddammit
Chill the f out, not everyone likes the bulky stock intake in there, I love the cleaner look of my bay with the CAI.
Old Jul 7, 2005 | 02:17 PM
Loe max's Avatar
10char
Old Jul 7, 2005 | 02:23 PM
sonicrunch's Avatar
whew!!
I just had to get it off my chest.
But why would you ever want to lose performance? For looks?
Old Jul 7, 2005 | 03:30 PM
Turbo1er's Avatar
whew!!
As if you lose much, Yeah, im taking my decade old Max out and slaughtering fools with all the performance! When I do decide to look at turbo or SC I will look more into it, but right now, the looks matter more, especially with the "maybe a little loss."
Old Jul 7, 2005 | 04:11 PM
sonicrunch's Avatar
"slaughtering"?
what, civics?
Old Jul 7, 2005 | 04:13 PM
1FSTMAX's Avatar
stillen has a carb eo number too..
Old Jul 7, 2005 | 05:06 PM
Turbo1er's Avatar
"slaughtering"?
what, civics?
What an idiot response, come on, read my response like you think you know how, like I said, I am more for looks now than performance, although the CAI "may lose some performance," although its been back and forth. I said chill the f out because your 7 inch yelling helps none.
Old Jul 7, 2005 | 07:04 PM
sonicrunch's Avatar
whoops..I misread that...
consider me
but I'm still faster!!!!!!!!!!!
Old Jul 7, 2005 | 07:11 PM
Turbo1er's Avatar
Whatever, retarded driver. But that is your mods right? Shirley.
Old Jul 7, 2005 | 09:07 PM
zander's Avatar
I have a "hacked" air box, actually I just removed the bottom of the airbox, I noticed it sucks alot of air in the mid range, but kinda trails off up top. So if you drive over 5 grand all the time get a CAI, where it will really matter. But if you are driving it daily a modded airbox will work just fine I think. And if you need some bling get a shiny mid pipe
Old Jul 7, 2005 | 10:10 PM
kodomo's Avatar
I just got a 98 maxima gle and I was thinking about making a few mods to it. I've never done any work on cars before so i'm basically inept at it all. I was also thinking about getting a stillen hi-flow intake as my first mod. How hard is it to install it myself? Or should I just find a shop to get it done at. Also can you guys suggest some very basic/easy mods I do?
Old Jul 7, 2005 | 10:23 PM
zander's Avatar
intakes are very basic and you should be able to do it yourself, easy.
Old Jul 7, 2005 | 10:24 PM
zander's Avatar
after that it looks like the best thing to do is Ypipe. but im new to this thing also. the more you read the more you learn, welcome to the .org
Old Jul 8, 2005 | 04:11 AM
kodomo's Avatar
thanks for the welcome, and do i need any special tools?
one other thing, the stillen hi flow, injen cai, and hks super mega flow, are all the same type intake mod, right? or can do combinations of them? ~_~ i'm really noobish.
btw, any idea how much it would cost to let a mechanic do my intake or y-pipe mod? in case installing them is beyond me.
Old Jul 8, 2005 | 06:19 AM
kodomo's Avatar
I was just reading about short ram vs CAI, doesn't the injen cai yield more hp than the stillen hi-flow? wouldn't getting a CAI be better then? and are there any other options for CAI systems for 98 maximas? please advise! it seems the more i read, the more questions i have... ~_~
EDIT:
oh yeah, can anyone give me an estimate on how long it would take for someone who has no understanding of working on cars to install a CAI?
thanks
TallTom
57
Oct 14, 2025 05:16 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
JonBlz
Oct 5, 2015 06:02 PM
Sep 27, 2015 08:37 AM
