are there any signs i should flush my tranny
Old Jul 7, 2005 | 05:04 PM
bigdog97max's Avatar
i was wondering if there is any way that i can tell that changing my tranny fluid is the right way to go. i mean i know that it's not a bad idea i have 103K on the car, but i was wondering if there are symptoms that the fluid is past it's prime.
Old Jul 7, 2005 | 05:37 PM
killerVQ30DE's Avatar
Yup, the trans fluid should be Red it turns brown/darker as the oil gets older and thin from all the heat in the auto trans. Check your auto trans dipstick.
You can feel a slight slip/hesitation when going between gears, like its dragging abit.. shifts should be quick and smooth on good trans fluid.
Its best to flush it anyway if your at all unsure, heat is the biggest problem with autos so without the trans oil you'll have problems
Old Jul 7, 2005 | 08:32 PM
i have a 5 speed tranny. the thing i'm experiencing is a kind of hesitation when first gear first engages. it's only after the car has warmed up a bit and i've been driving for a little while. first gear kinda shakes the car as i'm letting out the clutch and then engages abruptly, dropping the revs really low in the process. if anyone can tell me what this might be i'd really appreciate it
Old Jul 7, 2005 | 08:33 PM
cefiro8701's Avatar
if it shows numbers over 60000 on ur odometer.
Old Jul 7, 2005 | 08:37 PM
TurTLe*'s Avatar
i have a hard time reading the tranny oil stick. It always looks like its overfilled. Shouldn't it be like lower then the 2 crease. Just looks odd to me.
Old Jul 7, 2005 | 08:41 PM
kosmo886's Avatar
i think im going to flush my tranny fluid too...should the tranny filter also be replaced? and is this tough?
Old Jul 7, 2005 | 08:51 PM
cefiro8701's Avatar
i say have someone do it...im getting mine done as soon as i figure out how much college is gonna cost me.
Old Jul 8, 2005 | 09:16 AM
anyone have any opinions on what might be causing this. it's also only from a dead stop if that helps. i think it's getting worse and i want to get it taken care of before it becomes a big problem
Old Jul 8, 2005 | 02:15 PM
anyone......
Old Jul 8, 2005 | 02:43 PM
RockfordMax's Avatar
Back from the dead
no clue. i remember in the haynes manual tho it said drive around on it for like 30 mins to get it warm, then check level. it should be between the S curve in the dipstick. color also should be red like posted above.
Old Jul 8, 2005 | 10:50 PM
does the 5 speed have a dipstick, because i went out and looked all over and i can't find it. if there is one, could someone tell me where to look.
Old Jul 9, 2005 | 07:57 AM
anyone....
Old Jul 9, 2005 | 08:01 AM
Seximus Maximus's Avatar
Look in the stickies under the Fluids and Lubricants Section. You wil find what your looking for
Old Jul 9, 2005 | 08:05 AM
99MAXSE-L's Avatar
how do you flush and change transmission fluid?
Old Jul 10, 2005 | 06:40 AM
BlackCat's Avatar
RIP '98 Maxima SE
The 5 speed doesn't have a dipstick. You'll have to take off a bolt on the side where you put in the tranny fluid. To check the level you have to stick your finger in and feel for the level. Because you're feeling some slippage means your oil level is low. I felt this problem before with my '80 Honda Prelude 5 speed.
Old Jul 10, 2005 | 08:28 AM
MDeezy's Avatar
HOW TO's on flushing your tranny are stickied in the fluid section for both Manual and Auto trannies.
I'm glad I have a manual, its as easy and drain and refill.
Old Jul 13, 2005 | 04:50 PM
max4evr's Avatar
manual trans slippage
Sorry, any slippage in a manual tranny is not usually due to low oil level, it's due to clutch slippage.
Old Jul 13, 2005 | 05:08 PM
Hitmanforprez's Avatar
Another to tell the tranny fluid is done
Its smells almost burnt, and tastes horrible
j/k on the taste part, but the smell test works
Hitman
Old Jul 16, 2005 | 11:32 PM
ssr123456's Avatar
The transmission fluid must not only be red, but it must be bright red if it's fine. Once this guy showed me by putting some of my trans. fluid on a white ceramic tile and then putting some fresh fluid next to it. You don't really notice the difference until you look at it like that. When it has become a dull red, you need to start thinking about flushing it...any darker, replace it.
Old Jul 17, 2005 | 08:45 AM
Mmmaxx's Avatar
I thought it was more a pink color when it was good. Anyway, I think the manual says every 30,000 miles or so. I did mine at 33K for ****s and giggles and because they were having a combo oil/tranny fluish special. That was 3 years ago or so, Im at about 60K right now and plan on doing it again with the 60K tune up.
Old Jul 17, 2005 | 10:08 PM
ssr123456's Avatar
Well maybe I'm wrong, but I could've sworn it was supposed to be bright red. He showed me mine and it was pink I thought and he said I needed to get it changed.
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
RWCreative
Sep 21, 2015 11:01 AM
