How do you know when your clutch is going to go?
Old Jul 7, 2005 | 09:14 PM
Zipp028's Avatar
I have noticed a difference in my clutch grab and where it does in the pedal. It seams to be a lot deeper then usual and shifting is getting extremely notchy. It seams like i have to use force to get it into gear.
also
My 1st 2nd and 3rd gear are shaky around 1000 rpms to 3000 rpms can this be my axle?
Old Jul 7, 2005 | 09:17 PM
MDeezy's Avatar
If you clutch is slipping, thats the obvious sign its starting to go. you can adjust the grab point on the clutch to the proper location. If you have to use force to get into gear, you throw out bearing could be failing, need a transmission flush, or clutch again could be going?
is it 1st gear you're having trouble getting into? or all?
Old Jul 7, 2005 | 09:24 PM
Zipp028's Avatar
1st gear is pretty rough. the other gears seam notchy. i had new tranny fluid put in it when i got my passenger axle fixed (few months ago) so im pretty sure i dont need a flush. and i do have the "rollerskating" sound when idleing and clutch engaged but once i push the clutch pedal in it goes away but returns when engaged.
Old Jul 7, 2005 | 10:43 PM
2 Da Max's Avatar
when you let go of the clutch and the car is still bitting on that gear, and slowly comes off of it.
btw its easier to drive..well for me it was
Old Jul 7, 2005 | 11:26 PM
Laly's Avatar
my throwout bearing was bad on my sentra. it was hard to get into gear and if i had in gear with the clutch pedal down, it didnt feel like the car was completely in nuetral. the gear would grab a little and move the car up.
Old Jul 8, 2005 | 05:14 AM
wariow's Avatar
to test for slippage, at a stop put the car in 4th, hand brake up, and slowly let go of the clutch. If it dies immediately then you still hvae some grip left, the longer it takes to stall the worst condition the clutch is in, if the car is still running after depressing fully then u better run to the mechanic!
Old Jul 8, 2005 | 09:22 AM
Zipp028's Avatar
well i go outside today to start my can and it starts but it will not go into gear... any gear.....
Old Jul 8, 2005 | 09:27 AM
90stanza's Avatar
how does the clutch pedal feel when you push it down? do you have any pressure or non? if none it could be your slave cylinder went bad.
Old Jul 8, 2005 | 09:48 AM
MAXRB8's Avatar
Sounds like throw out bearing, while you're in there might as well replace the clutch anyway. This thread should help for parts:
http://forums.maxima.org/showthread....77#post4136977
http://forums.maxima.org/showthread....1&page=1&pp=30
http://forums.maxima.org/showthread....3&page=1&pp=30
Old Jul 8, 2005 | 01:01 PM
Zipp028's Avatar
yeah my clutch feels pretty loose untill the bottom part of it..
Old Jul 8, 2005 | 01:04 PM
MAXRB8's Avatar
If you have pressure, it's not your slave, still bettin it's your throw out bearing. Sounds like your clutch is toast now anyways, go 5th gen route haven't heard any negatives yet, unless you're going to boost
Old Jul 8, 2005 | 02:45 PM
Zipp028's Avatar
im thinkin 5th gen with the fidanza is that a good set up? I dont understand why the 5th gen is such a good clutch and I am wondering if my mechanic will allow me to give him a 5th gen clutch parts to put on..
Old Jul 8, 2005 | 02:59 PM
MAXRB8's Avatar
Your mechanic won't know the difference unless you tell him!
t/o bearing: 30502-41U20 = $24.50 Maxima 95-04
pressure plate: 30210-89F00 = $82.06 Maxima 2000
clutch disk: C0100-6E600 = $75.55 Maxima 2000
Rear main seal= $30.43
Old Jul 8, 2005 | 03:29 PM
Zipp028's Avatar
where are these prices from? Do y ou have a 5th gen set up? Do u like it as much as the entire org does? It seams to be the way to go....
Old Jul 8, 2005 | 04:50 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
If you're in 5th on the freeway and you floor it, do your RPMs rise without any coresponding change in speed?
Old Jul 8, 2005 | 05:17 PM
MAXRB8's Avatar
Those prices are from :
http://www.nissanparts.org/
I don't have a 5th gen set up as I don't need a clutch but when or if I do... seems I'll go that way!
Old Jul 8, 2005 | 10:47 PM
Zipp028's Avatar
So does anyone have the fidanza flywheel with the 5th gen clutch? How do u like it?
Old Jul 9, 2005 | 12:57 AM
Novo48's Avatar
it starts to let go. haha
Old Jul 9, 2005 | 06:13 AM
props000's Avatar
I was waiting till i had enough posts to ask this question myself...thanks OP.
Old Jul 9, 2005 | 07:16 AM
recardeeps222's Avatar
bad mama jama
the pedal will get heavier when the clutch is starting to go
Old Jul 12, 2005 | 04:36 PM
cranky's Avatar
I had to have my slave and master cylinder replaced last week and I noticed that it seems to be more difficult to shift gears after the repair. I get that notchy feel that Zipp028 described and I have to mash the clutch pedal into the floor to get it to shift. I don't think it was that bad before I got it fixed. So is it my throwout bearing going bad or did they not fix it right? The mechanic told that he thought the clutch would have to replaced in 10 to 15 thousand miles. I don't buy that explanation though.
Original clutch, 96SE, 140 thousand miles, and I don't drive it that hard.
Old Jul 16, 2005 | 01:46 PM
Zipp028's Avatar
well i bought a 5th gen clutch and a fidanza flywheel i hope this set up is going to be good. The problem with my transmission was my master cyl leaked and that casued it to break. i Noticed noises and vibration at lower gears such as 1st 2nd and 3rd. I replaced my clutch seeing i have 130k it sounds like the time to do so. how much does a used/new tranny job cost? i wish i had my own grage to do it my self its like im start to mech school (on monday) for nothing haha..
Old Jul 16, 2005 | 05:14 PM
RA030726's Avatar
I'm nutty for Nissans
when it takes all of its belongings and leaves a note.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
