Reoccurring ECU Codes
Old Jul 9, 2005 | 04:09 PM
coryf's Avatar
everytime there is good storm and alot of rain, my 1996 maxima (106k miles) starts throwing codes. however its always the same ones. "Knock Sensor" and "Front Right Heated O2 sensor". well i know its not knocking, and the O2 sensor has been checked repeatedly, no opening for moisture. could it really be over heating? and could my engine really be knocking even tho i have no degraded engine performance. i have had it looked at and maintenance agrees no issues. ECU issue?? any suggestions.
Old Jul 9, 2005 | 04:39 PM
njmaxseltd's Avatar
Replace the front right heated 02 sensor.
Old Jul 9, 2005 | 05:09 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
replace the o2 sensor. knock sensor code was proabably already there.
Old Jul 13, 2005 | 01:55 PM
coryf's Avatar
Heated O2 Sensor Symptoms
...Knock sensor code already there, does that mean it was knocking? On another note, what are some noticable symptoms of a Heated O2 Sensor?? Because i havent had any deminished engine performance or fuel issues.
Old Jul 13, 2005 | 02:00 PM
njmodi's Avatar
Do I get a tax break?
1. Bad o2 sensor will cause a loss in mpg.
2. No doesn't mean there was knocking - our cars are notorious for throwing the KS code together with any other real fault.
3. As already stated, replace the o2 sensor (bosch oem equiv. from oxygensensors.com), reset the ECU and you'll be set. Check again in a few days to make sure the KS code has not reposted (it will not set the CEL on its own). If the KS posts again (on its own) then replace that too.
/thread.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
