Shifter bushing review.... and RANT...
I'm totally lost here guys.....
I just installed my B&M shifter last week and didn't see any bushings etc etc. Unless of course you guys are talking about replacing the stock rectangular rubber that the OEM change rod attaches too....
.Thats the one... I just put in a new nissan one for $10.
How is the *** bushing different that the Energy Suspension bushing?.
If the *** bushing has polyeurathane and is stiffer, wouldn't that make shifting more difficult?
Anyway, I've only put 100 miles on my B&M STS and I like it, 3rd is a little tricky, but I figured I would get used to it. Trying to understand how this bushing can really help us 5spd guys with "easier shifts" and "cripsper shifting"=
I just don't get it.
The way I understand it, there are several bushings along the shift rods and support. When these bushings are cracked, shifting becomes sloppy or notchy because those rods start to flex as you apply pressure on it while shifting. With new stiffer bushings, shifting becomes smoother because the flex is not there when you throw the shifter into a gear, notchiness virtually disappears. Now with shorter shifter, shifter leverage changes as well as the throw (if its a STS), shifting might get notchy.
shifter bushing
exactly what is different? Aren't both poly bushings(that go in the same place and do the same thing)? Any physical differences?? What is specific advantage of $45 bushings vs $5 ????
They are in completely different places. I don't have my eFSM with me, but here.
shift rod: tranny input-----------------------------------shifter
support rod: ----()------------------------------------[]
The () is where the ES bushing goes. If you have ever changed your MT fluid then you know right where this is; the bracket that makes accessing the drain bolt so difficult holds this up. It is part of the pivot point between the tranny/engine and the shifter. There is NO ES shifter bushing for listed 5 spd maximas. The one for a 02-03 6psd Maxima DOES NOT fit. The one for a 91-94 sentra (don't quote me on year) will work, but it has to have the stud thing cut/drilled out and you have to replace the stud with a bolt/nut. I believe BlackbirdVQ was the one to first try this in his 5th gen. He posted about it in one of the ES engine mount threads.
The T E T bushing goes [] since it is where the support rod that holds up the shifter bolts to the frame towards the rear. It is a modified stock bushing that is filled with polyurethane. Both would make for really crisp shifter feel, but the T E T one would probably make a bigger difference since it has more play in it and it is closer to the actual shifter. If you know how to fool with polyurethane then you could probably make one yourself, but honestly it is worth $45.
I have an ES bushing sitting at my house, but I haven't installed it yet but I will soon. I did install the T E T bushing and I can say it did make a difference even with the stock shifter, but I hope to have my B&m once the upcoming SCO GD goes through then I will be able to compare to my friend's shifter with his b&m with stock bushing.
FORGIVE ME BUT :
DOES NOT HELP MY FEEBLE BRAIN,GOTANY PICS OR DIAGRAMS -- i JUST BOUGHT A 99 MAX 5- SPEED AND I WANT TO MAKE SHIFTING AS GOOD AS MY OLD 91 SE-R.
THANKS
THANKS
Here's a pic I got from Pinnacle Nissan... the two rods mentioned are shown here. Everything else should make sense. If you need a better picture, perhaps you should get yourself a Nissan FSM or a Chilton/Haynes manual.
http://www.pacesetterexhaust.com/quikshift.htm
Demonstrate on this picture what I am looking at for the poly filled bushing.
edit: If i could ever remember how to post a pic on this damn forum i would just post the picture itself, anyone wanna give me a 10second lesson?
This pic is for the wrong part, this is the shifter. The parts mentioned are the shift and support rods which runs along the underside of the car from the shifter mount to the tranny input. The bushings that are on those rods are the ones being discussed.
Originally Posted by DR-Max
This pic is for the wrong part, this is the shifter. The parts mentioned are the shift and support rod which runs along the underside of the car from the shifter mount to the tranny input. The bushings that are on those rods are the once being discussed.
knight_yyz
Nov 1, 2015 01:34 PM
atriuum
Sep 28, 2015 01:19 PM
wheres some digi pics
