code 0336? crankshaft position
Old Jul 11, 2005 | 05:52 PM
jackiss2888's Avatar
did the UDP and now im getting the 0336 code which reads "crankshaft position sensor a ckt range/perf" . . .is there anything i can do to fix this?
yes i looked in the CEL thread and i Googled maxima.org to no sucess
Old Jul 11, 2005 | 06:38 PM
njmodi's Avatar
Do I get a tax break?
Replace the sensor?
Old Jul 11, 2005 | 09:18 PM
TJ_Max's Avatar
Paradox Systems Vendor
are u sure u put the sensor back in correctly? or hopefully u didnt forget to throw it in, u know where it is right? side of the timing chain case....
good luck man...
Old Jul 12, 2005 | 09:05 AM
i dont think i banged it up at all and yes, i did unplug and clean it, and plug it back in after it threw the code.
i was reading and noticed that the stock pulley has a magnetic core. all aftermarket ones are aluminum, thus not being magnetic at all. i think this may be a possible cause for this, for the sensor uses the spacing and magnetism to do its "sensing".
also, can this cause anythign horrible? i noticed a sputter between 4500 and 6000 rpms in 3rd gear. anyone have any ideas?
Old Jul 12, 2005 | 01:05 PM
TJ_Max's Avatar
ahhhh, yes....magnetism, i just learned about this from looking at an sc set up....u can leave the cam sensor in even without the bolt being in because its magnetic it will hold...my guess is as good as yours...maybe the magnetic property is gone because of the pulley ure talking about...
Old Jul 12, 2005 | 04:03 PM
yea, but the sensor isnt the magnetic piece, it measures the magnetism in the magnetic core of the pulley.
maxinout93
Oct 31, 2015 02:04 AM
hayne
Oct 5, 2015 11:53 AM
