code P0133 => 0409...wat is it??
Old Jul 11, 2005 | 08:22 PM
MaximaPower's Avatar
been getting this code with the autozone scanner, P0133 which converts to 0409 from the ECU sticky thread, but the thread doesn't say what the 0409 is
the scanner said its the front O2 sensor, and the autozone guy said it was the one on the left....so i changed out the sensor and put a new one i got from the GD..i got autozone to reset it for me but after a few days, the code pops bak up again
anyone knows what else i should do? inspection time is here
Old Jul 12, 2005 | 06:49 AM
el_muchacho_qc's Avatar
Haynes manual:
P0133, flashing 0409 : Upstream oxygen sensor slow response fault (RIGHT bank)
BTW, don't pay a guy from autozone only to plug the scanner and get the codes out. Get acces to the ecm just beside the gas pedal, under a plastic plate. On the side of the ecm, theres a flat head screw. Turn it fully clockwise, wait at least 2 secs, and turn it fully counterclockwise. The check engine light will now flash codes. The number of long flashes represent first two number of code (in your case 04) and the fast short flashes are for the last two numbers of code (...09). To erase them, while you are in the flashing codes process, turn the screw fully clockwise, wait 2 secs and turn it fully counterclockwise. If you get new codes, post them on the forum or buy a haynes manual to know what they are (i think they may even be in the user's manual).
Old Jul 12, 2005 | 07:00 AM
njmodi's Avatar
Do I get a tax break?
Right bank is the one closest to the firewall - so you might have swapped the wrong O2 sensor. If you still have the one you pulled, swap that in for the O2 sensor that is really bad (the one on the y-pipe closest to the firewall).
Old Jul 12, 2005 | 08:21 AM
DragonMaxima's Avatar
Originally Posted by el_muchacho_qc
Haynes manual:
FYI: Autozone doesn't charge anything for a computer scan it's free.
Old Jul 12, 2005 | 06:36 PM
thanks guys....for some reason i kept thinking it was the left bank and i've had this code for quite some time now
i'll be changing it out this wkend so hopefully that'll take care of my CEL
Old Jul 12, 2005 | 06:47 PM
suicidalspd99
Is the right bank considered bank 1? I've heard some issues between this. Mostly my nissan dealer.
Old Jul 12, 2005 | 06:57 PM
njmodi's Avatar
The right bank is also called the rear bank or bank 1. (The bank closest to the firewall).
Old Jul 12, 2005 | 07:04 PM
kbmaxima's Avatar
i remember seeing a diagram or a layout of the o2's and which was left/right bank. I have a 99 calispec and i have no idea which o2 i have to swap for the 0702[0420] code i'm getting. front right bank. pre-cat. which one?!?
Old Jul 12, 2005 | 07:20 PM
njmodi's Avatar
http://www.courtesyparts.com/A32_O2-sensors.html
Old Jul 12, 2005 | 07:51 PM
kbmaxima's Avatar
Thanks. but geez. why do the 99's have to be so "special" ? i have one more o2 sensor than fedspecs correct? i'm wondering if that's the one that went bad. I have a sensor visible from the engine bay. damnit i'll just take a pic tomorrow.
Old Jul 12, 2005 | 08:17 PM
ahhhh....i thought bank 1 meant the left one
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
