Headlight brightness not the same
Old Jul 12, 2005 | 07:01 PM
PoKKi's Avatar
It seems like my passenger side headlight is dimmer than the driver side. I'm using the same KYO SuperBeam EX 65W/45W bulbs on both sides. At first it was dimmer because the passenger side's lense hazed up but I polished it up and it looks clear. But it still seems like the driver side is still brighter. Just wondering if it's the aiming and if I can reaim it myself? Would love to show a picture but my status doesn't allow for attachments.
Old Jul 12, 2005 | 07:09 PM
PandaXpress's Avatar
photobucket and generate the img link think...its free
Old Jul 12, 2005 | 07:12 PM
njmodi's Avatar
Do I get a tax break?
It could also just be that one headlight is aimed differently than the other.
Old Jul 12, 2005 | 08:33 PM
PoKKi's Avatar
Ya that's what I've been thinking that the passenger side isn't aimed as high as the driver side.
Old Jul 12, 2005 | 08:35 PM
aBoZoG's Avatar
aim it! Foo
Old Jul 12, 2005 | 08:58 PM
Nismotic's Avatar
Always sunny in philly
i had the same problem when i had bulbs. You might have a grounding problem.
Old Jul 12, 2005 | 09:12 PM
JPMax's Avatar
What's next!?..
Check the bulb sockets and wiring for any dirt or damage.
Then reaim the lights. Directions are in the Stickies.
Old Jul 14, 2005 | 07:00 PM
PoKKi's Avatar
Well I finally got a picture that really shows how much brighter my driver side is to my passenger side. In the picture, if the 2 headlights were the same brightness, the red circle should be around the same size. However, the passenger side is considerably smaller.
Would this be the wiring, socket, or aiming of the headlight?
http://i9.photobucket.com/albums/a73...u/P7150015.jpg
Old Jul 14, 2005 | 08:13 PM
Shady33e's Avatar
please explain cuz i hav the same problem with my bulbs...my high beams have the same lighting but on low beams my driver side is lower
Old Jul 14, 2005 | 08:15 PM
Shady33e's Avatar
wut i meant is how do i fix the grounding system, should i replace the whole bulb connection?
Old Jul 14, 2005 | 08:37 PM
Nismotic's Avatar
did you use aftermarket bulbs? ill be honest with you. I could never solve the problem and didn't get any answers on here as well. I switched out wiring harnesses, bulbs, everything, and still no prevail. jsut check the wires and make sure nothing has gone bad.
I just got HIDS to eliminate the problem
Old Jul 14, 2005 | 09:09 PM
Shady33e's Avatar
lol i guess i should do the same...but with a e46 retrofit lik in a post before this...
Old Jul 14, 2005 | 10:28 PM
99Automagic
It seems like EVERY car has this problem as it gets aged. I've seen it on many other cars, not just the Max. My car has the same problem, but I just accept it as being a common issue with all cars as it gets old. The only sure way to fix it, I think, would be to rewire the whole freakin car.
As long as the light reflexs off the eyes of small road critters as they stare at my car speeding at them, in shear terror, I'm satisfied.
Old Jul 15, 2005 | 06:17 AM
PoKKi's Avatar
LOL well i'm not overly concern...it's just that it could be annoying for oncoming traffic. I can see perfectly fine from my driver side heh. Besides...HID kits are way too expensive for me to afford right now...I need to save up to get my AC fixed. And yes I'm using aftermarket bulbs but the set I had before had a similar problem. Anyhow not overly concern if I have to play with wiring
Old Jul 15, 2005 | 01:33 PM
tbergma1's Avatar
Could be the bulb, try switching the bulbs and see if the same side is dimmer
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
