1st and 2nd Gear VERY NOTCHY !
Old Jul 13, 2005 | 10:23 AM
MaximA StyLeZ's Avatar
hey guys, well i was switching my intake due to all the comments stating stock is better, and it really is. ( I had frankencar midpipe w/ stillen filter). I went to go take it around the block and It is very hard to put the car into 1st and 2nd. Every other gear is fine, but 1st and 2nd gear are really hard to get in/out of. It still goes in/out, but very hard/notchy feel like you have to force it out. Any ideas why this is? Tranny? Clutch?
Old Jul 13, 2005 | 10:33 AM
Subzero's Avatar
In your case the factory intake is better, at least the engine can suck in some cold air. The ones by the battery in the factory location just get all hot air. Get a true cold air intake, you will notice a difference. And you probably need a new trans to, synchros bad??
Old Jul 13, 2005 | 10:34 AM
MaxxAddict's Avatar
Wait a minute. 1st and 2nd only became notchy AFTER you put ur stock intake back on? Is that what you're implying?
Old Jul 13, 2005 | 10:46 AM
MDeezy's Avatar
I'm sure your gear problems have nothing to do with you putting the stock intake back on. Check you clutch fluid, you could need a tranny flush.
If you honnestly think its your intake, put the aftermarket back on and see if its still notchy.
Old Jul 13, 2005 | 02:59 PM
no i was just saying that i put my stock intake back on... but when i went to go around the block, to test the diff. between the stock/stillen, i noticed that my 1st and 2nd gear was notchy........ you think i should put redline MT-90 ? or do you think my synchros are done ? i need help ASAP
Old Jul 13, 2005 | 03:45 PM
MaxxAddict's Avatar
....or bushings??
Old Jul 13, 2005 | 03:48 PM
Chief Brody's Avatar
Well how long has it been since you put new tranny oil in? It may be a good idea to change it, plus you can see if there is an inordinate amount of metal shavings that may clue you in as to the health of your tranny.
I also would recommmed making sure that it stays notchy. What I mean is that manuals by nature are a bit tougher to shift when the oil is cold. Does it still do it when warmed up by driving? Check out Fluids and Lubricants for more gear oil info.
Old Jul 13, 2005 | 06:15 PM
showoff's Avatar
WOW!!!!!!
This is halarious, the exact same thing happened to me this morning. It about 35 degrees outside and i drove my car to get oil, everything was just fine. Then after i changed my oil and drove it, it took all my effort to get it from 1-2 and it gets slightly better when it warms up. Check the Nylon bushing ball on the shift rod. In extreme heat it tends to swell and become deformed. Check that first and maybe re-grease it.
Old Jul 13, 2005 | 06:59 PM
Chickan's Avatar
top off your tranny fluid, also where does your clutch engage? In my 300zx I accidentily set it to engage too early, and could barely get it into 2nd and 4th only, thought my tranny was dead. Changed tranny fluid twice (even had nissan do it once, yuck), and was about to pull my tranny when I decided to adjust the clutch pedal, and wouldn't you know it. Adjusted it a bit farther out, and was fine afterwards.
Old Jul 13, 2005 | 09:04 PM
i changed my fluid when i installed a new clutch about 5 months ago. It was the POS Key value. I wish i knew about that when i purchased it. SO i don t know if it is actually the fluid. My clutch engages at a normal position, and I have never messed around with it. This problem is very weird. Im starting to believe it may just be the tranny/synchros. If anything I'm gogin to go with 5th gen tranny, 5th gen clutch, and fidanza flywheel. LOL all i need is the money. Does any1 have this setup ?
Old Jul 13, 2005 | 09:06 PM
Loe max's Avatar
Does it grind?
Old Jul 13, 2005 | 11:00 PM
Maxima lover
You are low of transmission fluid. Mine did the same thing when I was leaking. You lose the low gears first. Then when I would put more tranny fluid in, it would be fine. I eventually had to get another tranny after I dumped all my fluid in a parking lot one night and drove home with only 4th gear.
Old Jul 14, 2005 | 03:50 PM
I just had a "car-experienced" guy take a look at the problem and he stated that it is most likely my slave cylinder. Is this possible ? He pushed the slave cylinder in and i had no more clutch. I kno this is pretty wierd to explain, but thats what happened. So, I guess i'm going to change the slave cylinder and add MT90. Hope everythng works. Also, need 02 sensors, so I will prob do those to. oxygen senors.com still take 10% off, and how does this work ?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
