Replacing Serpentine Belt
Old Jul 14, 2005 | 03:15 PM
eclypsecl's Avatar
I need it changed..but because I now work without days off (money before i go on campus again) have no time time to replace it myself. Can anyone in the Boston area here suggest a good place to do this? I haven't had to take the max to shop before, did things myself (brakes*, gas filter etc )....so yah I'm stuck the belt is making crappy noises and it looks like the crank pulley is loose or something. Thanks!
Old Jul 14, 2005 | 03:42 PM
NmexMAX's Avatar
dot dot dot ...
I would do it but I'm not in the Boston area, so maybe you should try the regional forums to post something of this nature ... Did your brakes break, is that why you needed to do them?
Old Jul 14, 2005 | 03:56 PM
eclypsecl's Avatar
I can't believe I spelled that wrong.
Old Jul 14, 2005 | 03:59 PM
NmexMAX's Avatar
dot dot dot ...
You should change your location on your profile ....
Old Jul 14, 2005 | 04:09 PM
eclypsecl's Avatar
OK , done.
Old Jul 14, 2005 | 04:12 PM
NmexMAX's Avatar
dot dot dot ...
Are you in Alb or Boston?
Old Jul 14, 2005 | 04:14 PM
Chickan's Avatar
do it yourself, you can do it in under two hours tops, if you did your brakes yourself, belts should be no problem at all.
Old Jul 14, 2005 | 04:15 PM
THT's Avatar
THT
Throbbing member
Serpentine belt is a 45 minute job for someone who's experience with cars is limited to oil changes. Trust me, it's easy. Get a Haynes manual and start reading; you'll see how easy it is.
Old Jul 14, 2005 | 04:21 PM
NmexMAX's Avatar
dot dot dot ...
Not sure if he cares how easy it is, I think maybe because he doesnt have time ...
Old Jul 14, 2005 | 04:46 PM
eclypsecl's Avatar
I work a lot, time is tight. I've never tried to remove the belts, it looks tight and cramped in there, but I've read a FAQ somewhere. I'm just not sure if I want to risk messing this up and not being able to get to work.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
boomerbrian
Sep 4, 2015 08:25 AM
