My 97 wont start, what should I look for?
Old Jul 13, 2005 | 08:22 PM
Nathan's Avatar
Since we got the 97 SE 1/2 a year ago its been having starting issues on occasion, especially in extreme heat. Whenever you start it, there is a loud whine from the starter, and sometimes it requires 2-3 turns of the key to start it.
Well today when I tried to start it, I turned the key, it cranked for 1 second, and all of a sudden the noise from the starter dissappeared and the car wouldn't start. I tried turning the key several times after that and nothing happened. I could hear a slight hum when I turn the key (no clicking sounds), but other than that no noises from the motor.
I have yet to check the battery, but the battery should be good since its a pretty new AC Delco. All the lights are working, however I will check it tomorrow. Is there anything else I can check? Some local maxima guys suggested changing the plugs, cleaning the TB & IACV, trying to tap and/or regrease the starter, or check if the solenoids are gone.
Old Jul 13, 2005 | 08:50 PM
Loe max's Avatar
That humming sound is the starter spinning freely. That starter is dead. Try tapping it with a metal screwdriver and see if it catches.
Old Jul 13, 2005 | 09:00 PM
DennisMik's Avatar
yeah, i think you have a starter problem. it seemed like the bendix spring that engages the starter gear into the flywheel was messing up, but now the newest problem may be something else. i wonder if there is a fuseable link that may have blown, but i don't know the electrical system well enough.
Old Jul 13, 2005 | 09:09 PM
Nathan's Avatar
Ok thanks guys. I'm going outside now to tap the starter and see if it'll start. Tomorrow morning I'll check the battery.
Old Jul 13, 2005 | 09:24 PM
Chickan's Avatar
if you still hear in humming and lights work, chances are your battery is fine. Sounds like a starter problem to me
Old Jul 15, 2005 | 09:55 AM
Nathan's Avatar
Thanks for the advice/help guys. I was able to source out a rebuilt oem nissan starter within 1 day for $170CAD taxes in, (thanks to my 3rd gen friend Will), and I installed it last night and the car started beautifully.
I knew it was the starter after I tried hitting the old one with a screw driver, and it almost started.
Installation was easier than I thought. Thanks again guys!
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
