Raw gas smell -- can it be caused by quality/octane of gas?
Old Jul 14, 2005 | 09:23 AM
dr-rjp's Avatar
Here's a problem that really stinks:
For the first time ever, I'm getting the smell of raw gasoline upon start up, and it happened right after I decided to try mixing equal parts of Chevron 87 & 93 octane gas (to yield something equivalent to 91 octane).
Now, it may be because the 87 octane gas has a very, distinctive and strong smell that the 93 octane gas did not have, and I just did not notice it before.
Or, perhaps, Regular has a higher sulfur content since that is what it smells like?
Maybe the gas station's underground tank of Regular was on the low side and I got a lot of residue?
From what I know about smelling raw gasoline on start-up suggests there may be a problem with clogs or leaks in the EGR system, clogged or malfunctioning injectors, leaks in the manifold or Y-pipe, or just running way too rich.
For whatever the reason, the smell is there the day after I pumped the gas, and that is why I suspect that when I run this gas out, and fill it back up with straight 93 octane from another Chevron station, the smell will be gone.
Anyone else notice a change in odor (or an increase in odor) when changing grades or brands of gasoline?
Old Jul 14, 2005 | 10:05 AM
Nissan 6's Avatar
I bought my car from someone who used 89 octane gas then I started to use 93 octane gas and have not noticed anything different.
Old Jul 17, 2005 | 05:59 PM
dr-rjp's Avatar
Well, as expected, I filled my tank with 93 octane -- this time I used BP, and the raw gas smell is gone.
Nissan 6's Avatar
Yes thats what I used/use
Old Jul 17, 2005 | 06:48 PM
DUBCAPS's Avatar
I just switched to 93 and havent smelled the gas smell. I would always smell gas using 87. I would smell gas after driving around for a couple minutes. It would come in thru the air vents.
Old Jul 17, 2005 | 07:33 PM
2 Da Max's Avatar
that always happens to me.. when i start the car for the first time in the morning and i pull out the driveway i smell it hard.... maybe its the fuel filter??
Old Jul 17, 2005 | 08:09 PM
RobUsaf81's Avatar
Gas smell can be a sign of injectors going, just a thought.
Old Jul 25, 2005 | 10:36 AM
dr-rjp's Avatar
Sometimes, the harder is your car to start, the more the fuel/air mix accumulates, and when the engine finally does fire up, not all of it ignites.
In other words, unburnt gas fumes get blown out the exhaust pipe, and if it blows back in your direction, it smells like raw gasoline.
I do recall now that my car harder to start after I had put in that bad batch of gas I bought. Now that I've changed the gas, it cranks in one or two turns of the starter with no bad gas smell.
Old Jul 25, 2005 | 10:55 AM
2 Da Max's Avatar
what gas do you use? and i guess you are right about the unburned fuel, makes perfect sense
Old Jul 25, 2005 | 10:30 PM
DAVE Sz's Avatar
Hooooooonda.....
You have a small leak in your fuel system somewhere. I don't see how the quality of fuel could cause a bad smell unless your can't can't properly burn it off. It would be the car in that case not the fuel.
Old Jul 26, 2005 | 03:40 AM
SNOMAX's Avatar
PM me for LCA's!
I had the raw-gas-smell problem once. But it was due to a small plastic connector under the back of the car, near the spare tire well. It's where all the gas fumes collect--there's about 4 hoses on this connector. One was broken off. I'll try and get a pic if I can. It may be another place to look and it's pretty obvious once you know what you are looking at.
mpbclutch33
Dec 26, 2015 11:11 AM
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
