how often do u guys change ur coolant?
Old Jul 14, 2005 | 09:25 AM
Jonny98max's Avatar
i was just wondering how often u guys change ur coolant....if so do u notice any differences after changing it out....i have read the stickies and it says the red and green stuff are both good...what do u guys recommend
Old Jul 14, 2005 | 09:43 AM
Bobo's Avatar
Its supposed to be changed every 30K or 2 years. Take your car to a radiator shop and get them to do a pH test of the coolant to determine if it needs to be replaced. This entails dipping a special piece of paper into the rad and checking the color of the strip of paper. I don't think you would be charged for this test.
See the sticky in the Fluids and Lubricants forum about coolants. You are in the wrong forum.
I can't get too excited about what kind of coolant I use. What's good enough for the radiator shop is good enough for me.
My last coolant change was Cdn$40 cash. I can't notice any difference after changing it out, but your radiator will over time.
Old Jul 14, 2005 | 09:44 AM
mzmtg's Avatar
Minister of Silly Walks
Coolant is not tested by measuring the pH. It is tested by measuring the specific gravity.
I drain and fill my radiator about once a year.
Old Jul 14, 2005 | 09:55 AM
97SEdriver's Avatar
this place is dead
Are you sure?
The specific gravity depends on the amount of water you cut your coolant with, I can't see what that has to do with coolant health.
pH on the other hand, seems more likely, an acidic solution will eat the metal of your radiator. Flushing your coolant would flush out the acidic solution.
Old Jul 14, 2005 | 09:57 AM
Bobo's Avatar
After checking the Coolants forum on BITOG, I see both tests are done. Specific gravity can be tested using a floatation device, but pH is tested with a strip of paper. I am referring to the latter test, which is the one conducted to determine whether or not the coolant has lost its effectiveness.
A one year drain and fill is probably overkill and a waste of money, depending on how many miles you drive.
Old Jul 14, 2005 | 01:39 PM
ImmaSquashYou's Avatar
if you think you need to change your coolant, then change it, it isn't all that hard. its like saying, i think i need a shower, but i'm going to ask all the other people if i smell....
Old Jul 14, 2005 | 01:54 PM
1MAX2NV's Avatar
Every two years I go with the a coolant flush. Nothing worst than ruining a water pump on the VQ.
Old Jul 14, 2005 | 02:41 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
every 30K.
Old Jul 16, 2005 | 11:14 PM
ssr123456's Avatar
What are you looking for when you need to change your coolant? I looked at mine and the color doesn't look bad, but I've passed the 30,000 mile mark.
Old Jul 17, 2005 | 06:32 AM
tuner001's Avatar
ya mine hasnt been changed fopr a while either and the color still look fine but i guess it couldnt hurt if i had it flushed
maxipower
Aug 21, 2015 11:10 AM
Turbobink
Aug 17, 2015 04:11 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
RealityCheck
Aug 5, 2015 06:18 AM
