Key Ring Led?????
how do u type like that? doesn't it get annoying and tiring?
all u have to do is put an led into the existing bulb holder. This requires u taking apart the kick panel and the covers going around the steering wheel. if u can stomach doing that, then you're set.
Originally Posted by ruffrida24444
Anyone Who Did Leds In Their Car What Did You Use For The Key Ring??? Did U Buy A Led Bulb For There From Somewhere Or Solder A Led In There?? Any Info Will Help Thanks
Why would you want to type in caps in the first place
i never knew typing in caps was such a big deal................
i just happen to have it on and when i was done typing i didnt feel like typing all that $hit over again........
but yea. the keyring mod is easy. once u take apart the dash, you'll see the keyring part. follow the wire, disconnect. bring it in side with u. place an led in place of the bulb. go back to your car, test it out, voila. o yea, always rememeber to disconnect the neg. on ur battery. JUST in case.
the answer for ur question is simple...
open up ur steering column...take out that part..the bulb will have a green or blue condom looking dealie...(i think its a 194...i read this from a 5th genner)..get a sharpie and color that whatever color u want...put everything back together and ur done...
cefiro did that blue bulb dull at all over time??? and u only put one in there correct?? thanks
im gonna do this soon though...don't really car if it fades...so long as its not green anymore...that mess was ugly
The key ring pops right off if you just give it a little wiggle, the connector is about 6 inches back. As for the LED, the old one was hell to get out, ended up shattering it into a million pieces with a micro-screwdriver. I put a blue T5 (Which is the same as a #74) SMD LED in mine, fit perfectly.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
thread ...
