Corssmember PAIN!!! help
Old Jul 14, 2005 | 04:43 PM
madnut's Avatar
I have been trying to remove my crossmemeber bar for 3 days now, F***ING dealer has cranked the bolts to death, i got 3/4 of em off but the forth one wount budge. Even worce the bolt head got bent from my rachet now i cant even get a good grip on it. What do i do???
Id go to a shop but then i have to place my ypipe back and drive to to the shop and have them remove ypipe and get the bolt off, but that will prolly be costly.
I JUST WONNA KILL THAT LIL HO AT THE DEALER THAT KILLED IT ON!
Old Jul 14, 2005 | 05:15 PM
maximus_96's Avatar
get a breaker bar from autozone. the 3' ones break anything loose
Old Jul 14, 2005 | 05:42 PM
madnut's Avatar
im using a 20" one and it wount bundge
Old Jul 14, 2005 | 05:45 PM
bhmax16's Avatar
Either a bigger breaker bar or an impact wrench would do it I'd think
Old Jul 14, 2005 | 05:50 PM
sunten1
i assume you already tried wd 40 and all that other fun stuff?
Old Jul 14, 2005 | 05:56 PM
86maxima96's Avatar
I Broke OT
I used a big steel rod on my suspension bolts. definitely about 6' long. i could do with my pinky what i couldn't do with my whole body.
that sounds kinda weird...
Old Jul 14, 2005 | 07:59 PM
vqmax
breaker bars own all that are tools and pb blaster works damn well if its rusty.
Old Jul 14, 2005 | 08:47 PM
konak85's Avatar
lol
10char
Old Jul 14, 2005 | 09:07 PM
AsthmaMax11's Avatar
Get creative and leg press the mother ****ers, I did that a few weeks ago and I finally broke them loose. How bad is the ratchet slipping? I mean I bent the **** out of my bolts but the socket eventually locked on.
Old Jul 15, 2005 | 08:35 AM
MrEous's Avatar
^ Jeff™
You said the 'bolt head got bent'...does that mean you rounded it off?
Just curious.
Also, why are you needing to remove the crossmember?
Old Jul 15, 2005 | 09:16 AM
madnut's Avatar
one of the faces got a lil bent, so i didnt round the whole thing... but the socket wount sit streight on it anymore
I could try the 6' thing but i dont know if i can lift the car high enought to use somth that long
Old Jul 15, 2005 | 09:31 AM
nismos14's Avatar
§è~® f®ÈÄk
Why are you removing the crossmember? WON'T WON'T WON'T WON'T WON'T
Old Jul 15, 2005 | 09:32 AM
STROIKA1's Avatar
which crossmember bolts are you trying to remove? The reason I ask is because I tried removing the bolts that hold the motor mounts to the crossmember, and the rear motor mount bolts were a real pain to get to . it was easier to remove the long bolts that run through motor mounts at the motor and leave the mounts on the crossmember. the bolts that fasten the crossmember to the frame came off with an impact pretty easily. if the bolt head is getting rounded, make sure your using a 6 point socket and make sure it is the right size! dont use a 12 point. also, if your using cheap tools, they might not fit to good. Use a decent quality 1/2" drive impact type socket and a long breaker bar as mentioned above.
Old Jul 15, 2005 | 01:47 PM
D-Twelve's Avatar
Bigger Hammer!!!
Old Jul 15, 2005 | 02:51 PM
f550maranello2's Avatar
bro use some heat and wd40.. and get a half inch drive ratchet with a 3 foot pipe and it will get ANYTHING loose.
madnut's Avatar
GOD DEMMIT!!!
After getting a better socket and putting a nice and long pipe on the breaker bar I got it moving... BUT TO MY DISMAY its the whole bolt moving !!!
I am now bathing the thing in WD40 in hope that itll let go of the bolt itself and unscrew...
STROIKA1: Interesting advice after the WD40 bath try i will try the engine bolts thouse cant spin .
PS: this sucks becaouse im sick right now and dont have too much strenght for this bolt fighting!
Old Jul 15, 2005 | 03:56 PM
MrEous's Avatar
^ Jeff™
Dude...can you let us in on WHY you are trying to take it off in the first place?
Please?
Old Jul 15, 2005 | 04:03 PM
bhmax16's Avatar
Please?
I too would like to know this. My buddy that I work at my shop with just had some major reinforcement done on his crossmember on his 80s Monte Carlo. He has a friggin 502 engine it in and his crossmember nearly fell apart. Now all is well...but yeah, why are you removing the crossmember?
Old Jul 16, 2005 | 03:00 PM
madnut's Avatar
One needs to remove it to get to some of the tranny bolts in order to drop the transmission.
BTW i got the damn thing off, but now i need to buy a new bolt becaouse i ruined that one
Old Jul 16, 2005 | 03:30 PM
MrEous's Avatar
^ Jeff™
Why didn't you just take out the bolts from the motor mounts and remove the crossmember that way?
2 bolts and you're done...
Old Jul 16, 2005 | 03:48 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Uhh, so when you take those 2 bolts off - do the other 4 that bolt the crossmember to the chassis magically undo themselves and come off the chassis?
He's doing it correctly.
Old Jul 17, 2005 | 03:52 PM
MrEous's Avatar
^ Jeff™
D'oh...was I drunk yesterday?
lmao
Old Jul 17, 2005 | 08:27 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
OT But I have ES Motor mounts, do I have to remove the cross member to get at the motor mounts?
Old Jul 17, 2005 | 09:29 PM
madnut's Avatar
Two out of the 4 motor mounts sit on the crossmember so to replace thouse you would have to remove the crossmember.
Finkle
Sep 27, 2015 09:53 PM
16_SR
Sep 9, 2015 07:14 PM
FlaMark
25
Aug 28, 2015 10:15 AM
t6378tp
Aug 24, 2015 07:03 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
