brembo or OEM rotors? OEM or aftermarket pads?
Old Jul 15, 2005 | 09:57 PM
Jonny98max's Avatar
i am plannin on changing out my front brakes....i just havent decided on what i want yet.....
i have been thinking about goin with OEM rotors and pads...but also i have been thinkin about brembo rotors with some aftermarket pads....
i want something that wont have much brake dust...and also some with NO ANNOYING NOISE!
what do u guys recommend?
Old Jul 15, 2005 | 10:33 PM
1996blackmax's Avatar
OEM
I have aftermarket rotors and pads but they dust a lot and give a little noise once in a while. To me the better braking is worth it. If you want to mantain quiet braking and low dust, stick with what came with the Max.
Old Jul 15, 2005 | 11:35 PM
cefiro8701's Avatar
my dealer charges 87 per rotor...psh...brembos i go.
Old Jul 16, 2005 | 01:02 AM
aznsap's Avatar
why do your front rotors need to be changed? usually u can get by with just changing the pads.... unless your rotors are cracked/grinded. if there's nothing wrong with them just get some good pads that don't dust very much.
Old Jul 16, 2005 | 01:47 AM
WielkiWaac's Avatar
MaximaDriver
why you asking stupid question? if he wants to change it let him do it.
Old Jul 16, 2005 | 01:57 AM
Gates's Avatar
If you want less noise and less dust, definately stay with OEM pads. Aftermarket pads will dust more and are more likely to make noise. They definately stop better than OEM though, I just put Hawk HPS pads in and they stop great. No noise yet either.
Old Jul 16, 2005 | 03:58 AM
Frank Fontaine's Avatar
I swear by OEM. I did my fronts and rears, at different times, and nary a squeal or groan. I even forgot to put the shims back in on the fronts, no problem. They seem to last a heck of a long time too (changed my fronts in the 50's, and they had 40% left, changed my rears at 89k, probably had 20% left)....
Old Jul 16, 2005 | 06:46 AM
MaximaPower's Avatar
have raybestos quiet stop up front with OEM rotors for about a yr now, and no problems or noise at all
Old Jul 16, 2005 | 07:19 AM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
is there a difference between Brembo blanks and OEM rotors? any advantage of one over the other?
Old Jul 16, 2005 | 09:20 AM
browne's Avatar
bump......
Old Jul 16, 2005 | 11:02 AM
http://maxmods.dyndns.org/index.php?MaximaPerformance
http://maxmods.dyndns.org/index.php?MaximaBrakePads
http://maxmods.dyndns.org/index.php?MaximaBrakeRotors
Old Jul 16, 2005 | 11:13 AM
doesn't answer my question, but thanks...
Old Jul 16, 2005 | 11:22 AM
I beleive my Powerslot rotors are Brembo blanks which are then slotted. I have had no issues with mine, no warping at all. If I were to buy new replacement rotors (not slotted or drilled), I would go with the Brembo blanks over OEM to save some cash. There are many people on here who use them with OEM pads and are happy with their performance.
Old Jul 16, 2005 | 11:35 AM
Thanks, thats the kinda info I'm looking for! I'm thinking about Brembo blanks and Raybestos QuietStop, which hopefully will be an improvement over stock yet still conservative.
Old Jul 16, 2005 | 11:43 AM
I've read that the quiet stops are not really an improvement over the OEM pads, but a good (less expensive) alternative. I have not used them so I can only tell you what I have read. Maybe other people can chime in on the Raybestos.
Old Jul 16, 2005 | 12:12 PM
improvement in what?
raybestos still create lots of dust
Old Jul 16, 2005 | 12:36 PM
grip. i'm looking for a setup that will moderately increase grip but not squeak.
Old Jul 16, 2005 | 12:40 PM
i didn't notice any difference in grip
Old Jul 16, 2005 | 02:20 PM
cefiro8701's Avatar
quietstop sucks...wish i never got them...
Old Jul 16, 2005 | 02:22 PM
y do they suck?
Old Jul 16, 2005 | 02:39 PM
cefiro8701's Avatar
i have silver rims....and they make them look like...they're wooden...
Old Jul 16, 2005 | 08:07 PM
I have Hawk HPS pads and they have better stopping ability than OEM, have not had any issues with brake fade.
Old Jul 16, 2005 | 09:49 PM
1996gle's Avatar
I have 1996 maxima GLE, i just changed all 4 rotors and pads..
i have 4 Brembo rotors drilled and slotted with Axxis brakes..
Best price i found for it was on Ebay from r1concepts really really great guys!!! they shipped 4 rotors with front and rear Axxis brake pads for $270... The parts came in like 4 days... and all the rotors were in the brembo box and they all have BREMBO embedded on the.. I think they are much much better over the stock rotors/pads.. I can feel the difference, there is just a bit of dust and NO NOISE!! If you are planning to change the rotors and everything, i would STRONGLY suggest paint your calipers also.... I have used FoliaTec paint, RED color.. it looks REALLY REALLY hot with 17in Konig Verdicts wrapped with Nankang tires.
Old Jul 16, 2005 | 10:55 PM
cefiro8701's Avatar
you just helped me make my decision...
where'd u get them?
Old Jul 16, 2005 | 11:18 PM
The answer to your question is in his post and on your quote of his post .
Old Jul 16, 2005 | 11:35 PM
goldtooth's Avatar
do you still have the OEM rotors or did you get some other ones ?
Old Jul 16, 2005 | 11:38 PM
i do know wat u mean...i have silver rims too, but i dont think the dust is much or any worse than from OEM pads
Old Jul 16, 2005 | 11:54 PM
beefy23b/97's Avatar
I changed out my front rotors with brembo's and PBR semi metalic pads. They are great, no noise and awesome braking, takes some seriouse hard driving to get them hot. I wouldn't recommend going slotted unless your racing. They stop great but the slots cut up your pads and make alot of dust.
Old Jul 17, 2005 | 12:15 AM
d00df00d's Avatar
Old enuf to pick his own gears
Yes, slots may wear your pads a little faster. But they also keep dust and grime from staying caught between your pads and rotors, which helps prevent scoring (which means you have to replace your rotor). I don't know why people keep forgetting about this, but it makes a BIG difference sometimes.
I'm running Brembo slotted front rotors, Brembo blank rear rotors, and Axxis/PBR Ultimate pads all around. $335 shipped from www.importrp.com. No noise, very good pedal feel, excellent response (close to OEM) and stopping power (MUCH BETTER than OEM) for the price, and not a lot of dust.
Old Jul 17, 2005 | 12:21 AM
I have been using Powerslot rotors for a couple of years now.
http://www.powerslot.com/pages/power_slot.html
Old Jul 17, 2005 | 01:42 AM
ilyaat's Avatar
I just changed my f/r brakes. Looks like the nissan OEM are sumitomos o.O
Old Jul 23, 2005 | 12:38 PM
tech_auto's Avatar
Has any tried the PFC Carbon Metallic or the PFC-Z pads? I've had great experience with them on a GM intermediate.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
knight_yyz
Nov 1, 2015 01:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
