Air Bag light
Old Jul 16, 2005 | 06:00 AM
eclypsecl's Avatar
Air Bag light
Aisde from the fact that my serpentine belt needs changing, all of a sudden my Air Bag light began flashing. I came in on a hot day and my steering wheel was extremly hot, and that's when the light started to flash. Is this a sensor? Could the air bag be bad?? Wtf do I do...and damnit I sprung an exhaust leak now.
Old Jul 16, 2005 | 06:21 AM
mendon99's Avatar
tastey wheat
cant find the air bag light fix link that worked. i think it was something like:
1. get in your car, open the door
2. turn key to ON position
3. find rubber surrounded button on door sil that is depressed when door is closed
4. press it 10 times within ten seconds, quickly
5. shut your door, turn the key to OFF position and DO NOT TAKE OUT THE KEY
6. start the car, see if it worked, worked for me
Old Jul 16, 2005 | 06:34 AM
eclypsecl's Avatar
are you serious??
Old Jul 16, 2005 | 07:02 AM
mendon99's Avatar
tastey wheat
Originally Posted by eclypsecl
are you serious??
nope, im just joking
Old Jul 16, 2005 | 07:08 AM
eclypsecl's Avatar
well, I did it...and it worked...my air bag light is off...wtf...none of us at work can understand why.
Old Jul 16, 2005 | 07:22 AM
mendon99's Avatar
tastey wheat
you're welcome
Old Jul 16, 2005 | 08:25 AM
eclypsecl's Avatar
it stil keeps blinking after the reset, a few min after to be clear...are there any sensors there that can be replaced? Or any other recommendations?
Old Jul 16, 2005 | 11:39 AM
95jr6708's Avatar
mine goes off as well and i cleared it as well. the only thing i have heard that can change this is to take it in and have the airbags "replaced." which is around a lot of money. so i just said screw it and left it, cuz its not worth it too me. if you just want it to go away so it doesnt look ghetto with a blinking light disconnect the light.
Old Jul 16, 2005 | 04:11 PM
eclypsecl's Avatar
is there a sensor that was tripped?
Old Jul 16, 2005 | 05:13 PM
Iron Scimitar's Avatar
Tha Snatcher
I had my flashing air bag light diagnosted at a local NISSAN dealership. They told me that it was a sensor thats under the passenger side seat that needs to be replaced. Cost was about $1000 w/ labor. They are outta their damn minds.
my air bag lite is still flashing to this day.
Old Jul 16, 2005 | 06:46 PM
eclypsecl's Avatar
Wait, so why not get the same sensor from the junkyard? It can't be that hard to replace. Who the **** puts an airbag sensor under passenger side seat???????? Is there a way to diagnose the airbag code myself?
Old Jul 16, 2005 | 11:30 PM
maximariceboi's Avatar
i have the same problem too....but its from my airbag module on my steering wheel airbag...i cant just replace the sensor..gota replace the whole airbag....mine is still blinkin for about 1 1/2 yrs already...i thought of maybe tryin to change the sensor but its not possible...well...good luck man...if anything for inspection..try takin off the light bulb or putting black electrical tape..thats what i did and past inspection last month =]
Old Jul 17, 2005 | 10:21 AM
eclypsecl's Avatar
well, I read the stickies and found out that if I have a 99..it might be the passenger side seat airbag. So I smacked it hard, removed the junk from under the seats...voila. No more light blinking.
Old Nov 7, 2005 | 08:13 PM
Ruthless's Avatar
ok, The button in the door pillar hey.. So thats the lil black button right inbetween the front and back door.... And when you touch it, the door ajar button flashes right??? Well, I left the key in the on position and pushed WAY over 10 times in 10 secs and then put the key to off, then turn it on right away,the air bag light goes solid, then starts flashing right away..... Should it stay off for a little? or start flashing right away?
Old Nov 8, 2005 | 06:19 AM
eclypsecl's Avatar
open door, press the little nipple black thing 10 time fast, close the door, turn the key to off, then turn car on. I can't remember if it's that or , press 10 time, turn off car close door, start car. It's one of those.
Old Nov 8, 2005 | 11:05 AM
L.I. I30t's Avatar
There is a TSB on the passenger side air bag wire. The wire that comes with the car is too short and over time can throw a flashing air bag light. Usually what I do is move the seat forward and back while in dianostic mode of the flashing air bag light, then turn the car back on and it is gone. I would had change it but the revised part is expensive from the dealer.
Old Nov 8, 2005 | 02:39 PM
buffy's Avatar
I just wanted to thank you guys. I was wanting to post that very question, however found out that I needed 15 posts. This is my first. I tried to reset the light it kept flashing. I moved the passenger set forward and back, smacked it a few times and so far it's out.
Great forum, thanks again.
Old Nov 8, 2005 | 11:10 PM
dimension45's Avatar
Thanks ive been looking all over for what might be wrong when the light started flashing and the dealership said they didnt know what could be wrong until they charge 90 bucks for a diagnostic. thnx
Old Nov 9, 2005 | 06:21 AM
Tha Snatcher
holy shiet, you serious? did you put it into diagnostic mode or did u just move the passenger seat back and forward at any time?
Old Nov 9, 2005 | 07:58 AM
HomerMAC's Avatar
Donating i30 Owner
alot of the times the clock spring can go bad in the steering wheel...
thats a common problem.. well thats what happened with mine.. reset works for a while then blinks again... then when i put the preforated steerign wheel on.. it went away.. for liek a month and after 1000nds of turns it came back.. so i came to conclusion Fit.. my car has over 100,000 miles. .not worth spend toomuch money to fix.. unless i come along a clocksrpring by anychance...
(ALSO VYNL paint works GREAT for spraying my brown airbag black to match my black sterring wheel..)
so yea.. i put in an SE cluster.. and so i opened up teh guage and well where the airbag light is... i took a peice of black electrical tape.. and cover the square where the light is behing the guage face.. so now no annoying blinking airbag light... its annoying at night speciall.. heh.. and my girlfirend is alway complaining.. is the airbag gonna blow up... and crap so i got tierd of the comments so i covered the light.. so fat works for me... all my airbags will still deploy except for hte steering one... i guess.. i get is scanned to make shure its not the other airbags... for passenger saftey...
Old Nov 9, 2005 | 11:41 AM
buffy's Avatar
I moved the seat froward and back, smacked it a few times and went through the key on, toggle door switch 10 times, turn ignition off, then start car. So far after 100 miles light is still off.
Old Nov 11, 2005 | 02:08 PM
buffy's Avatar
Well I found out last night that the air bags were still OK after resetting the light. Some lady ran a red light and I T boned her. Both air bags inflated as expected. I'm sure he Max is totaled, will be looking for another soon I hope.
Buffy
Old Nov 11, 2005 | 06:08 PM
kormax97
Buffy
wtf so you joined the org and after 3 posts you recked your max?.... and some odd coincidence those 3 posts were about airbags...
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
