Overheating..done everything...i guess
Old Jul 18, 2005 | 10:23 AM
Kbuitre's Avatar
thinking on replacing the manufacture fans and installing a high-performance set...any input will help...
Old Jul 18, 2005 | 10:33 AM
mzmtg's Avatar
Minister of Silly Walks
If your car is overheating with fully functioning OEM fans...aftermarket isn't going to stop it.
Old Jul 18, 2005 | 10:35 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
when are you experiencing overheating such as conditions? have you checked the coolant temp sensor? i assume by everything you mean you have changed the thermostat, radiator cap, flush and refill and checked the radiator itself?
Old Jul 18, 2005 | 11:20 AM
MAXIMIZETHIS's Avatar
check the following. coolant level, radiator cap, thermostat( by seeing if the upper radiator hose gets hot when the fan turns on....this indicate the thermostat is opening at about 180 degrees farenheit). Check the fans. If everything works out try bleeding the system to remove any possible air pockets
Old Jul 19, 2005 | 09:00 PM
Kbuitre's Avatar
Only on the hot weather days and as long as i drive around 70 mph is fine the problem is when i push it to speeds over 80 mph.
Old Jul 20, 2005 | 06:48 AM
joesmith's Avatar
Take the car to a car wash and wash down the radiator and ac condenser. The helped a bit on my old truck. You be suprise how much dirt and other crap are on the radiator fins. If you have a steam cleaner that would work even better.
Old Jul 20, 2005 | 01:05 PM
wahoohead's Avatar
water pump?????
Am I missing something?? or partially closed thermo.
Old Jul 20, 2005 | 05:48 PM
nismos14's Avatar
§è~® f®ÈÄk
Wow how about also take that ugly a$$ pic out of you're signature. It could be a number of things, but maybe letting us know what you have already done would help out a bit.
Old Jul 20, 2005 | 10:08 PM
TJ_Max's Avatar
Paradox Systems Vendor
lol, not to hijack, but man check my overheating thread and read from there.....i did all that and STILL overheating....good luck
Old Jul 20, 2005 | 10:23 PM
cefiro8701's Avatar
well... since we're talking about cooling systems....
does the cooling system contribute to our MPGs??
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
