How do you wire new gauge cluster??
Old Jul 19, 2005 | 11:17 AM
PatDezNuts's Avatar
I just picked up a set of white gauges that are indigo and was able to install them without a problem. The only thing now is that I don't know how to wire them to the head lights; the description was VERY vague on that part. Where do I run the wire or where do I splice into the another wire so it is tied into my headlights when I turn them on?
Old Jul 19, 2005 | 12:31 PM
ihadahonda's Avatar
look in your drivers side fuse box. there should be a fuse labeled headlamps or something to that effect. take the fuse out. strip 1/8" off of the red wire. wrap one prong of the fuse with the red wire. reinsert the fuse. ground the black wire.
Old Jul 19, 2005 | 12:45 PM
PatDezNuts's Avatar
Thanks, that helps a lot. I love the directions they give you, they didn't help for jackcrap through the entire process. God bless this site.
Old Jul 19, 2005 | 01:48 PM
JPMax's Avatar
What's next!?..
Another option is to splice it to the power wire going into the dimmer switch on your dash (blue wire, i think) and then just put the ground wire under the screw in the back of the cluster thats marked GND.
Old Jul 19, 2005 | 04:10 PM
RA030726's Avatar
I'm nutty for Nissans
the gauges have their own dimmer correct? if so tapping into the oem dimmer will make you very unhappy. they need a full 12 volts to work properly. Use the Red with a blue stripe wire located in the driver kick panel. That is the parking light wire.
Miket2006
Mar 1, 2021 03:55 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
