Please Help! Cel- Why??
I am getting 1-11:
Heres the info from the sticky:
0111
Diagnostic Trouble Code 0111 is detected when ...
- EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
In particular:
Would this be for MEVI install?
Because I had a "bad" mevi install. If it does include this I might be able to fix it.
Timing is critical as I need to freakin pass smog and register the car this week.
Thanks anyone who knows and is willing to help.
0111
In particular:
Yea, the mevi install might have a vaccum leak somewhere. Would that do it?
I think however, that I might be OK, I found a hose that was kinked- it was the one from the (Solenoid?) to the throttle body. Man, I hope that fixes it because I am gonna have to go the the dealership if not..
Have you got a strut brace make sure its not crushing the canister hose for your EVAP
http://forums.maxima.org/showthread.php?t=211145
ChuckDaMaxRider
Dec 12, 2004 05:25 PM
