Pulled out the NGK BKR5E-11 spark plugs
Old Jul 20, 2005 | 07:25 AM
Justaguy's Avatar
Here's a look at the plugs (NGK BKR5E-11) after 44,000kms.
1. Did they needed to be replaced?
2. There was no more NGK BKR5E-11 in stock, so I went with BKR6E-11 this time (better for cold starts as per http://forums.maxima.org/showthread....80#post2815980)
Also note that I was guilty of using cheap gas
http://www.premiereproduction.net/fi...ies/spark1.jpg
http://www.premiereproduction.net/fi...ies/spark2.jpg
http://www.premiereproduction.net/fi...ies/spark3.jpg
thanks
Old Jul 20, 2005 | 07:27 AM
MDeezy's Avatar
Look like normal wear to me.
suicidalspd99
Since you pulled them changed them. I would start using the better gas.
Old Jul 20, 2005 | 07:31 AM
speed racer's Avatar
They look normal.
Old Jul 20, 2005 | 07:45 AM
Justaguy's Avatar
normal meaning they needed to be replace or I could of waiting a little more?
Old Jul 20, 2005 | 07:48 AM
MDeezy's Avatar
I'm not sure how long 44,000kms is in miles but, they look like they could last a bit longer in the car, but seeing as you have them out migh as well change them.
Old Jul 20, 2005 | 07:58 AM
Bobo's Avatar
44,000 km is just over 27,300 miles or 91% of what they are supposed to be good for.
Old Jul 20, 2005 | 08:05 AM
kcryan's Avatar
They probally could go longer but i would just change them out,
Are these the platniums or the coppers?
MDeezy's Avatar
With that said then yes change them, your sparks are in a healthy condition, 30K is about the lifespan of the coppers.
Old Jul 20, 2005 | 08:12 AM
UncleMax98's Avatar
Those plugs look like platinum. Are you sure you want to change to copper? Copper is fine, but you need to replace it more frequently than Platinum.
Old Jul 20, 2005 | 08:14 AM
Jeff92se's Avatar
I'm needing a caw
Those are plats and are rated to 60,000 miles.
Old Jul 20, 2005 | 08:20 AM
kcryan's Avatar
So the coppers are rated for 30k?
Old Jul 20, 2005 | 08:22 AM
MDeezy's Avatar
Yes.
Old Jul 20, 2005 | 08:33 AM
MrGone's Avatar
thanks
Those are not BKR5E-11's
Old Jul 20, 2005 | 08:36 AM
Jeff92se's Avatar
I'm needing a caw
Isn't the p/n printed on the ceramic portion?
Justaguy's Avatar
The new ones I bought are NGK BKR6E-11 V-Power Copper..I didn't see any platium ones.
Dam..I could of left the platinum ones in there a little longer
Old Jul 20, 2005 | 10:12 AM
DennisMik's Avatar
is the electrode in the center supposed to be tapered like that? I've never pulled my plugs out (as you can tell).
Old Jul 20, 2005 | 10:15 AM
njmodi's Avatar
Do I get a tax break?
Yes (for the plats at least).
Old Jul 20, 2005 | 10:20 AM
prelude2005's Avatar
Yea I have never seen it tapered like that...weird
Old Jul 20, 2005 | 10:24 AM
Bobo's Avatar
Did you toss out the plugs you removed? Those plugs look to be in good shape to me.
Old Jul 20, 2005 | 10:57 AM
NmexMAX's Avatar
dot dot dot ...
Sure those aren't Platinum? Electrode looks a bit small (Pt = higher density than Cu)
Old Jul 20, 2005 | 12:51 PM
Justaguy's Avatar
I never said they were.. I don't know what they are, but when I get home tonight I'll check the label on it and report back.
Does anyone have a pic of what a bad spark plug looks like? This will help for next time
Old Jul 20, 2005 | 12:53 PM
njmodi's Avatar
is your friend.
http://www.densoiridium.com/howtoreadusedplugs.php
Old Jul 20, 2005 | 12:55 PM
NmexMAX's Avatar
dot dot dot ...
Buy a haynes, or use for a spark plug reading chart ...
Actually you DID say they were
Old Jul 20, 2005 | 02:57 PM
Justaguy's Avatar
Oops your right...I made a mistake on the subject line...
Okay the plug I pulled out was a : PFR5G JAPAN NGK R is that platium?
Thanks NJMODI for the URL....I did google, but was looking for an actual pic. your site was even better! Pic and explanation.
Old Jul 20, 2005 | 03:37 PM
njmodi's Avatar
You are welcome, and yes that is a platinum plug.
Old Jul 20, 2005 | 08:02 PM
twiggy144's Avatar
Another vote for a normal and light wear plug here.
Need help
23
Oct 2, 2015 08:56 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
