Anyone interested in purchasing harness to convert 9004 to 9007 Headlights?
Old Jul 20, 2005 | 07:54 AM
Chickan's Avatar
I'm building a custom harness to convert my headlights from 9004 to 9007, and I was wondering if anyone would be interested in me producing a harness for them. This would be all new wiring, and would require some work on your part, but very minimal. The harness would be able to support upto a 110 Watt bulb, though I would only advise a 100 watt bulb in order to maintain some margin of safety.
There would be two options available:
1) Just the harness: $55
2) Harness with 80/100 Watt Bulbs: $70
An addon to both, I would enclose the relays and most of the wiring for $10. This would clean up the install considerably, and make it easier for you to mount.
All prices include shipping, and if there is at least a few people interested in this, I'll make up a few sets, though they would be made to order. Delivery time would be about 10 days after ordering, depending on certain conditions (mostly my availability, as this takes a good chunk of time to wire up). The huge advantage of this kit over the other harnesses on the market, as all the current that powers the headlights will be run on 12 Gauge wire, while the rest of them use your old wiring for part of it. In my setup, the only thing your old wiring would do is trip the relays. This would be a complete bolt on kit, and you would not need to purchase anything else. The only tools required would be tools to loosen and tighten your battery terminals, and a pair of pliers to crimp a few wires. Full installation instructions would be included.
I will have a working model installed on my car within a week, and will post pictures and comparisons at that time.
EDIT: Set includes new sockets, though it appears some filing may still be required. I will update this when I am able to test it out in a few days.
Old Jul 20, 2005 | 08:02 AM
suicidalspd99
I would put this in the for sale section to. I might think about it. I know i heard of people saying that the high beam pattern was real bad. i want to see a maxima with the setup in it.
Old Jul 20, 2005 | 08:03 AM
njmodi's Avatar
Do I get a tax break?
May want to mention that you would still have to file the nub down in the headlight bulb mount right for the 9007 bulbs. i.e. its almost "plug and play".
Old Jul 20, 2005 | 08:05 AM
Chickan's Avatar
actually mine includes new sockets, so you dont have to file it down.
Old Jul 20, 2005 | 08:08 AM
njmodi's Avatar
Thanks for the clarification - it is worth mentioning that in your original thread - it's added value for sure.
Old Jul 20, 2005 | 08:09 AM
suicidalspd99
I thought that the headlamp set inside the headlight housing. I thought regardless you have to file a nub off. I'm getting more interested now.
Chickan's Avatar
Added it, thanks!
Old Jul 20, 2005 | 08:10 AM
njmodi's Avatar
Thats what I was getting at... but I trust Chickan understood that - so he's found way to get around that problem... or maybe not.
Old Jul 20, 2005 | 08:12 AM
Chickan's Avatar
I may be wrong, but I was under the impression that the problem was with how the bulb was inserted into the socket itself. I'll know for sure when I get my bulbs in the mail.
Old Jul 20, 2005 | 08:13 AM
Chickan's Avatar
As stated above, I'll check it out when the bulbs come (hopefully tomorrow), and if it still does need to be filed off, I'll do it for the customer
Old Jul 20, 2005 | 08:49 AM
wahoohead's Avatar
interested in part
I'd be interested in the HD 9007 sockets and the bulbs. I already have a harness with relay's that is running regular wattage silverstars the only kind available. Running 100 watt bulbs burned out the sockets. I have never liked the lighting on the Maxima's. I'd consider tye 9007 to be the last lighting I'll try.
Old Jul 20, 2005 | 08:58 AM
Tatanko's Avatar
Bacon Lover
I'd be in if this could be made to be plug and play. Or is it? I don't think I quite understand...
All I know is, I'd love to convert to 9007 but I'm not the greatest with wiring or anything like that and I'd like to be able to just swap something directly that won't require any cutting/splicing. I hate splicing
Old Jul 20, 2005 | 09:23 AM
Chickan's Avatar
This kit would be perfect for you! You would need to cut your stock wiring, but all parts are included. Make a few simple connections, mount the relays (really easy w/ the box), and you are ready to rock!
Old Jul 20, 2005 | 09:24 AM
Chickan's Avatar
Once I get my kit working properly, I'll get you a price on just the bulbs and th socket, probably around $25 shipped.
Old Jul 20, 2005 | 09:56 AM
Black Maxima
This 9004 to 9007 mod is so easy a cave man could do it.
Old Jul 20, 2005 | 11:02 AM
Chickan's Avatar
but not a cave man without some time and energy, and also some electrical knowhow. I'm planning on offering a drop in kit that would be a sinch to install.
Old Jul 20, 2005 | 11:07 AM
Tatanko's Avatar
Bacon Lover
Hmmm...so a person who completely sucks at wiring would be able to do it? I'd like to see what all needs done before I purchased it and couldn't install it
I can do a few splices real quick by using wire taps, but that's gonna get old real fast if I have to do half a dozen of them...especially in a limited space like a fuse box or something...
Old Jul 20, 2005 | 12:58 PM
TurTLe*'s Avatar
i'll be interested once i see those pictures.
if you can only do the conversion on 1 side so we can see the diffrence and same with both hi/low beam patterns as well.
Old Jul 20, 2005 | 01:04 PM
Chickan's Avatar
Turtle, I will surely do that, and pictures should be available within a week.
Tatanko: Heres the list of what you would need to do on your end, and anything that is possible to be done on end will be done:
1) Attach supplied to cable to both battery terminals, using supplied orings
2) Cut low beam positive line from one headlight, crimp to new cable via supplied butt connector
3) Cut high beam positive line from one headlight, crimp to new cable via supplied butt connector
4) Cut ground line, crimp to new cable via supplied butt connector.
5) Mount relays (or box if desired)
That is really about it. More detailed instructions would accompany the kit.
Old Jul 20, 2005 | 01:15 PM
Tatanko's Avatar
Bacon Lover
Wow...that sounds pretty easy actually. Now in step 5 you say "or box if desired," does that mean we can get a box to mount somewhere in the engine bay instead of having to do more electrical work?
Old Jul 20, 2005 | 03:39 PM
Chickan's Avatar
The box I'm refering to is an option I stated, where for $10 I'll enclose all the relays and fuses and such. This would just dramatically clean up the install, make it much easier on the eyes. There is a good spot I've found to mount it, and I'll make pictures available of the entire install process. And yes, it would be really easy for you to install, which is my goal in this process.
Old Jul 20, 2005 | 04:38 PM
dawalkster's Avatar
is craving Bojangles
group deal..
oh, and what headlights are included in the $70 package?
Old Jul 20, 2005 | 07:34 PM
RA030726's Avatar
I'm nutty for Nissans
i have a better idea to tap in for power. a quick splice works wonder.
butt connectors would be far more desructive to the wires, and you need a crimp tool.
almost makes me want to sell these for $55
Old Jul 20, 2005 | 07:49 PM
Chickan's Avatar
I've thought about making them with those connectors on them, and the final version probably will for most connections.
Old Jul 20, 2005 | 07:51 PM
Chickan's Avatar
Originally Posted by dawalkster
group deal..
The headlights are generic/standard 80watt/100 watt 9007 bulbs, nothing too fancy. If you wanted something higher grade, you are welcome to just get the harness, and supply your own bulbs. Any 9007 bulb rated up to 110 watts would work with my setup.
Tatanko's Avatar
Bacon Lover
Those wire taps are what I used to do my foglight rewire. They aren't TOO hard to use...
Old Jul 20, 2005 | 08:00 PM
Chickan's Avatar
nope, wiretaps are pretty straight forward, and part of it would already be attached too.
Old Jul 20, 2005 | 08:05 PM
Maxima_Joe's Avatar
4th Gen Parts King
You can buy these harnesses on ebay and just flip the low beam and high beam wire.
Old Jul 20, 2005 | 08:31 PM
wahoohead's Avatar
no to the wire taps
I don't think the crimp wire taps are the way to go.
Old Jul 20, 2005 | 09:29 PM
Chickan's Avatar
The harnesses on ebay still use your stock wiring to carry some of the load for the headlights, the stock wiring will burn up if you try to run 80/100 watt bulbs off of it.
Old Jul 20, 2005 | 09:30 PM
Chickan's Avatar
The crimp wire taps would only be for the lines to trip the relays, not for the power lines themselves. If you are interested in a set, I can include butt connectors instead for you.
Old Jul 20, 2005 | 09:44 PM
DAVE Sz's Avatar
Hooooooonda.....
There is no need for a 9004 to 9007 harness unless you're switching to higher wattage bulbs. If you're staying with the stock 65/45 bulbs NO HARNESS IS NEEDED.
Old Jul 20, 2005 | 10:43 PM
quasidynamic's Avatar
2 things, please correct me if i am wrong about this one, but aren't our lenses incompatible with the vertical beam pattern of 9007 bulbs? our lenses are specifically designed to work with a horizontal pattern and i believe the vertical beam would not refract properly and would create a nasty glare...
secondly... i found a solution to melting stock harnesses with 80/100 bulbs. Go to a wrecking yard and cut the stock harnesses off of an 88 or 89 maxima (or any older nissan for that matter). For some reason these dont melt, perhaps they were made with better plastic. I picked up a pair for $2 + $2 entrance fee to the yard. couple splices and i was all done 5 minutes later. havent melted on me in over a year...
hope this helps...
Devin
Old Jul 21, 2005 | 03:38 AM
Jatan's Avatar
Our 9004 housings won't handle the full potential of the 9007 bulbs, but it'll still be better than the stock 9004 bulb setup
Old Jul 21, 2005 | 05:49 AM
Chickan's Avatar
Read my full post, it is for up to 110 watt bulbs.
Chickan's Avatar
hope this helps...
Devin
if you want to use 16 year old wiring in you car, you are welcome to it, I wouldn't trust it personally. Sounds like a fire waiting to happen.
Old Jul 21, 2005 | 08:04 AM
Actually, they are safer that our stock harnesses as well as store bought aftermarket harnesses; both melted on me. The old harnesses don't. It's like they say, they just dont make 'em like they used to...
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
JoshG
Sep 5, 2015 10:10 PM
