Neon installation..
Old Jul 20, 2005 | 03:03 PM
MystA RavE's Avatar
Neon installation..
For those of you who have neons under the dash...where did you secure it to on the drivers side? What about on the passengers side, on the little ridge part?
Pics would be helpful.
Thanks!
Old Jul 20, 2005 | 03:06 PM
sunten1
Everyone is going to call you a ricer.
But I am going to tell you a little advice, go and get CCLFs not neons. CCLFs are cheaper then neons (like half the price) you can buy them on ebay.
They are used on the computer to light up the computer from the inside. They are hell of a lot brighter and last longer. But you will have to do a little bit of custom work.
You can also use zipties to help keep the wires organized and in control and on most CCLFs I have see there are square blocks on each end that are flat so you can velcro them down to the plastic (under the dash) or you can always just ziptie them to something under there...
Old Jul 20, 2005 | 03:09 PM
MystA RavE's Avatar
I already have the street glow sound sensitive ones I just need to know exactly where to place them...
Old Jul 20, 2005 | 05:04 PM
craig10114's Avatar
on the passenger side if you take off the glove box you can secure them tightly to that cross bar with electrical tape.
on the drivers side i found the best way is to zip tie them to the wires under there so they stay tucked up there
no offence but neons are pointless...they look good when you show it but thats about it. its one of those mods you do when you first get the car and think how cool is this. but if you like em then go for it. make sure to put a fuse on your power line, and your switch on the ground....
Old Jul 20, 2005 | 05:38 PM
MrGone's Avatar
you forgot they run cooler and use less electricity
Old Jul 20, 2005 | 05:39 PM
goldtooth's Avatar
what if my cold cathodes have a switch on the red wire ( power ) not the black ( ground ) wire ? Is that something i should change ?
Old Jul 20, 2005 | 05:49 PM
sunten1
It doesn't make a difference
Old Jul 20, 2005 | 07:31 PM
happyricefob's Avatar
V^___^V
i used zip-tie
Old Jul 20, 2005 | 09:50 PM
goldtooth's Avatar
Originally Posted by happyricefob
i used zip-tie
what he said ^^^^
Old Jul 20, 2005 | 09:53 PM
TJ_Max's Avatar
Paradox Systems Vendor
ditto, i zip tied to wires under drivers side, and zip tied them under glove box when i was doing something where i had to remove it (the ps2 install i think)
i craig i got laid twice thanks to neons "oooh ure car is pretty, wow i like the lights" it does something to em, so keep hooking ure car up, girls dont know wut rice is, they think its pretty....lol
Old Jul 20, 2005 | 09:58 PM
Black Maxima
That's sooooooo true, all the misses be all up on my jock because of my blue interior lights...
Old Jul 21, 2005 | 09:39 AM
craig10114's Avatar
tj knoows how i do
Old Aug 20, 2005 | 09:30 AM
Chiciak
bumpbumpbump
Old Aug 20, 2005 | 09:44 AM
sunten1
Originally Posted by Black Maxima
That's sooooooo true, all the misters be all up on my jock because of my blue interior lights...
AHAHAHAHAHA
Old Aug 20, 2005 | 01:15 PM
ImmaSquashYou's Avatar
my accord used to be a christmas tree..kinda cool at night. with my system, it was almost like a disco party around my car when we had nothing to do at night .but then i finally realized...i spent a good 20+ hours wiring up all my neons....i just don't have the time to do it for this car nemore...plus i have an i30..i dun think i can put neons on there...it'll look wierd...
P.S. make sure that noone will hit the light n crack it on the passanger side. na also on the driver side, secure it, n not just like oh whatever. it can be dangerous if it suddenly falls while you need to brake...make sure you use a fuse. i believe i used 15 amps. 2 of them in fact in case one didn't cut it.....but make sure you wire it neatly n not just having them plug into your cigarette lighter...cause thats just gay..
Old Aug 20, 2005 | 01:56 PM
InsneDrmr's Avatar
i ziptied mine on a bar underneath the seat....lights up the whole car nice and even. Looks better than under the dash. But like everyone else...i found it was a waste of time, i never use them.
Old Aug 20, 2005 | 03:35 PM
Magikone69's Avatar
i used zipties for the seats, and for under the dash i cut lil strips of double sided tape. holds up very nice...i too have CC tubes and they are very slim, light and have are very bright, they are quiet too, ive noticed some neons have a slight hum, and with 2 or more tubes it can get noticeable. check my cardomain for pics.
Old Aug 20, 2005 | 08:44 PM
matts95max's Avatar
man use anything u can to keep it up as long as it cant be seen from sittin in the seat. I think I have used wire ties and packaging tape(dont recomend!)
teejnut
May 1, 2001 04:57 PM
tomz17
Mar 20, 2001 04:06 PM
punkdork
Feb 7, 2001 09:43 PM
sx7r
Dec 15, 2000 08:13 PM
