cel 0705
Old Jul 20, 2005 | 08:38 PM
Maxima_Joe's Avatar
4th Gen Parts King
cel 0705
Ok guys i know what it means. I also got 0903 which is
Diagnostic Trouble Code 0903 indicates a problem with the Evaporative Emission (EVAP) Canister Vent Control Valve or its associated electric circuit.
There was a nipple for one of the hoses that was busted off.So i fixed that and there is no longer the 0903 code but the 0705 still remains.Every time i fill up with gas it is always under alot of pressure which i think is causing the 0705 code.So what could possibly be wrong.I have two 4th gens so i can swap the part out to see if it is the part that's bad.
0705
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
Old Jul 20, 2005 | 11:28 PM
kc10fish's Avatar
dude alot of those things you can ck yourself. alot appear to be ck the gas cap for forien matter and so forth.......just take alook and then come here. good luck though
Old Jul 21, 2005 | 02:49 PM
Maxima_Joe's Avatar
4th Gen Parts King
So is there a good chance that the system being under so much pressure is what is causing the cel?
jmlee44
Oct 2, 2022 02:13 PM
MaxDD
Sep 24, 2015 06:40 AM
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
ballerchris510
Sep 10, 2015 09:35 PM
