Suggestions On Strut Bars, Sway Bars, Lower Tie Bars
Old Jul 21, 2005 | 09:56 AM
206maxima's Avatar
I am about to get a strut bar and a sway bar for my 96 max. suggestions? I saw a Bhlemco Stage II lower tie bar from liuspeed. Is it necessary to have two for the front? Top and bottom? will it make it handle and prevent bending better? Are ther lower tie bars for the back too? Appreciate suggestions. Thanks!
Old Jul 21, 2005 | 10:06 AM
mindlessoath's Avatar
is the tie bar an "anti-sway bar"? if so its worth it to have one on the back, and i think one comes on the front stock. (if im not mistaken).
but a front strut is worth it, the rear strut is not needed but if you can find one for cheap they do help allittle... but its not worth it, IF its to expensive.
other than that i dont know to much about it.
Geophrum's Avatar
custom enterprise sells a good rsb and you can either get there fstb or go to e-bay and get one for cheep
as for the tie bars i am unsure whose are the best.. so if you find out let me know
Old Jul 21, 2005 | 10:21 AM
206maxima's Avatar
I am planning to get the rear sway bar from custom enterprise. I saw the strut bars from paradox systems too. then the lower tie bar from liuspeed. check them out. here are the links. I don't want to get generic ones coz i feel like they'll break or something.
http://www.liuspeedtuning.com/products/a32_tiebar2.html
http://www.paradox-systems.com/performance.html
(I'm looking at the heavy duty one. what do you guys think?)
Rear Sway Bar from Custom Enterprise
http://www.customenterprise.com/view.../vts/design017
Old Jul 21, 2005 | 11:42 AM
206maxima's Avatar
anyone? ???
Old Jul 21, 2005 | 10:04 PM
86maxima96's Avatar
I Broke OT
wow! do you really need the heavy duty one? i couldn't even justify spending $100+ on a FSTB!! that thing looks super heavy too. it doesn't look like it would clear the AC piping very well. hmm, check e-bay. best best imo...
Old Jul 22, 2005 | 12:55 AM
SPiG's Avatar
SomePsychoGuy
Ebay for FSTB, the $100 one would probably not make a difference you would feel or it would not be enough to spend the extra $75 on.
Go to matt blehm for LTB. http://www.mattblehm.com/suspension.htm
Progress or stillen RSB, but some have said it is not good to have if you are lowered a lot or at all. With stock springs it is supposed to make a big difference.
Old Jul 22, 2005 | 09:57 AM
i belive all my gear was bought from stillen
Old Jul 22, 2005 | 12:51 PM
99grnmaxgxe's Avatar
Don't buy a strut bar that's made by Otto Racing. It looks cool but you have to modify the mounting base on your car.
Old Jul 22, 2005 | 03:00 PM
Uncgolf's Avatar
i bought a fsb from racingdimensions and i went to put it on and it hits some hoses and a cylinder, i have no idea what it is that its hitting anyone else have this problem.
Old Jul 22, 2005 | 06:17 PM
happyricefob's Avatar
V^___^V
fstb - get it from ebay
rsb - get it from CM (progress/addco tech)
ltb - get it from blemhco
fstb - increase responsiveness on steering, slightly improve cornering
rsb - stablize rear-end, but introduce over-steering
ltb - good combo if u have rsb, cuz it reduce over-steering
i donno how to explain it, but one day when u 0wn all these mods u'll understand...
Old Jul 22, 2005 | 08:35 PM
86maxima96's Avatar
I Broke OT
actually, I have this installed on my Max, and after just pressing down with a little weight on the AC hoses, it fit fine. no play and no rattle. no contact.
Old Jul 23, 2005 | 04:12 PM
Uncgolf's Avatar
yea i just put mine on and once you tighten it up it fits fine.
Old Jul 23, 2005 | 08:00 PM
FishyMan's Avatar
speaking fo ftsb. is there any 4 point ftsb for our maximas?
or 1 piece ftsb. im notl ooking to spend much, but i dont want cheap ebay ones that are thin enough to be good for civics. our cars are much diff't. i would think, thicker, stiffer 1 pieces would be good.
Old Jul 23, 2005 | 08:07 PM
86maxima96's Avatar
I Broke OT
what do you mean 4-point? do you mean instead of 3 bolts at the top of each strut mount, there should be 4? cuz that doesn't make any sense and would not work. the struts only have 3. or do you mean 4 parts?
Old Jul 23, 2005 | 08:14 PM
FishyMan's Avatar
well for some cars... they mount at 4 POINTS hence the name. i think the 2 towers and the other 2 at some other part of the chasis near the back..
the ftsb mounts on 2 points (regarldess of bolts) the 2 front struts. im just curious if theres some that mount the traditional 2 front tower as well as the
Old Jul 23, 2005 | 08:49 PM
you would have to make your own... the most common is two connections from what i gather.
Old Jul 23, 2005 | 10:02 PM
86maxima96's Avatar
I Broke OT
oh, ok, now i know what your talkin about. like a 4 point as in more bars? like a 4 vs. 5-point racing harness? my friend has a 2002 SI, I believe and last time I saw it, I asked her to pop the hood and it had a bar and then two other bars that connected to the rear of the engine bay, near the firewall. would that be a 3 or 4 or anything?
Old Jul 23, 2005 | 10:57 PM
FishyMan's Avatar
ya that type of thing 3 or 4 points pending. but ya the idea is there..
i meant to type firewall but i d k i kept thinking firewell or something haha.. but ya..
Old Jul 23, 2005 | 11:36 PM
1996blackmax's Avatar
Get the least expensive front strut tower bar, if you are not going to lower your car get the rear anti-sway bar. The RSB will be very noticeable on a stock height Max.
Old Jul 24, 2005 | 05:31 AM
maximariceboi's Avatar
is there any other site for the lower tie bar? i was searching for blemhco lower tie bar but there was nothing for the maxima....
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Stagnet04
Sep 14, 2015 11:28 PM
Violator
Sep 9, 2015 10:14 AM
