Overheating & Cooling Fast
Old Jul 21, 2005 | 10:45 AM
ryant35's Avatar
Last night I noticed my temp gauge in the red, so I quickly stopped at a gas station and shut off my car. I grabbed a flash light and couldn't find a leak, the overflow resivour was empty. I filled it, and restarted the car, and the gauge went back to normal.
No leaks, & both fans work.
As I was driving I noticed that the higher the rpm, not car speed, the lower the temp would go. 30, 40 50 mph, no difference, but once I turned off overdrive, the rpm jumped over 3000 and the temp dropped fast! 2 seconds from top to normal. In the few miles home, this would repeat every time I would slow down, so I would keep it in low gear. This morning it didn't do it 30 miles to work.
My guess in a sticky thermostat, and once the rpm gets high, the water pressure opens it up. And a rush of cool water runs in and makes the gauge drop fast. I guess.
What do you think?
Old Jul 21, 2005 | 11:14 AM
njmodi's Avatar
Do I get a tax break?
Sounds like either a bad gauge temperature sending unit - right near the engine coolant temp sensor in the upper radiator hose towards the drivers side of the front valve cover
OR
A bad temp gauge in the cluster.
I can't imagine that the temp would drop that suddenly if the thermostat was suddenly opening... but
Old Jul 21, 2005 | 11:33 AM
DennisMik's Avatar
check and see if the radiator fan is spinning. the fan is supposed to be temperature controlled not related to speed or engine rpm but check it anyway
Old Jul 21, 2005 | 12:07 PM
ryant35's Avatar
The fans were running.
Old Jul 21, 2005 | 12:08 PM
ryant35's Avatar
at idle speed
Old Jul 21, 2005 | 02:29 PM
ryant35's Avatar
OR
I guess thats could be it, I just noticed that when I was under the hood, it wasn't very hot. Not more than normal anyway. And I've been under the hood of a car that did actually overheat, and you can feel & smell it.
Old Jul 21, 2005 | 07:54 PM
JoeB
Sounds like an air bubble in the cooling system. Also a bad head gasket can cause this problem (rare in a max).
Old Jul 21, 2005 | 09:58 PM
TurTLe*'s Avatar
yea i'm thinking air bubble especially since you where out of coolant in the overflow tank. Drain and refill the coolant. See if that fixes the problem.
Old Jul 22, 2005 | 08:03 AM
ryant35's Avatar
It stopped doing it now, if it does it again I will drain & refill the coolant.
Thanks.
Old Jul 22, 2005 | 09:47 AM
TJ_Max's Avatar
Paradox Systems Vendor
if that doesnt work check out all these problems.....
http://forums.maxima.org/showthread.php?t=416416
Old Jul 27, 2005 | 01:22 PM
ryant35's Avatar
Well. Its not a gauge. Its an air bubble caused by a leak in the water pump seal.
Which means $600 for a new water pump at the dealer.
I would do it my self, but once I told my boss that I would have to take a day off of work, he agreed to pay for it. Sweet. He also bought the car.
Old Jul 27, 2005 | 01:31 PM
Maximized Jiggs's Avatar
WTF? Where did you find a boss like that. Dont tell me you are sleeping with him.
Old Jul 27, 2005 | 01:32 PM
njmodi's Avatar
Can I work your boss.. I mean, "work for" your boss.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
