tranny question
Old Jul 24, 2005 | 03:48 PM
rome06's Avatar
tranny question
this only happens in 3rd and 4th gear but if im over 4,000 rpms and shift into 3rd it grinds a little bit and is kinda difficult to get into.....if im doing over 60 and downshift into 3rd then it grinds too...clutch is all the way to the floor....4th gear is the same thing...what can be the problem.?????? ALSOOO i went got my ecu scanned and code (PO0325) popped up and it says "Malfunction exists in the electrical circuit for knock sensor 1. ( Bank 1 or singe sensor) (Bank 1 identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank" what does this mean and how the hell do i get it fixed....thanks a shiitload guys
Old Jul 24, 2005 | 03:52 PM
AggressiveFront's Avatar
For teh grinding, you syncro is screwed up. The codes, it is probably refering to cylinder 1, just replace it.
Old Jul 25, 2005 | 12:30 PM
rome06's Avatar
anyone else??????????????????
Old Jul 25, 2005 | 12:48 PM
Chickan's Avatar
for the grinding, have your tranny fluid changed, and possibly go to a thinker gear oil (say GL4 or GL5, instead of GL3). Helped a ton on my 300zx.
For the knock sensor, do some tests, there is a good writeup in the "how to's"
Old Jul 25, 2005 | 05:25 PM
rome06's Avatar
i got that checked out and the mechanic said the tranny fluid is at level even a tiny bit above level and it just got changed a year ago when i bought the car (about 12,000 miles ago)
Old Jul 25, 2005 | 05:53 PM
rome06's Avatar
can it be the syncronizers???? i try not to drive my car hard but u kno how it is with 5 speeds u get into that mood sometimes.....but i'll go buy that redline mt-90 tranny fluid and see if that helps and any other opinions would be helpful!
Old Jul 25, 2005 | 06:14 PM
If you have a gear lube that is too thick it will cause it to feel notchy, which is why redline is so good. It is a better viscosity and makes teh shifts smoother. Since it is actually grinding, I re-iterate the synchros.
Old Jul 25, 2005 | 06:23 PM
Loe max's Avatar
Try this:
Go ahead and do your high rpm upshift but:
Push in clutch
release gear
go to neutral
wait a second
now move the lever to your desired gear
Does it grind now that you've waited about a second to let the revs drop?
rome06's Avatar
im not tranny smart.....how the hell do u get to the synchros??? and how would i re-iterate them?? lol
Old Jul 25, 2005 | 06:25 PM
Loe max's Avatar
synchros are little clutch-like devices that suppliments gear changes to allow for non-rev matched upshifts and downshifts (to a certain extent). They are located inbetween the gears in the transmission box.
www.howstuffworks.com can explain it to you with actual video demonstrations, its quite useful when trying to learn how a manual transmission operates.
Old Jul 25, 2005 | 06:26 PM
jaedaliu's Avatar
reiterate means to say again; he's emphasizing his point to check your synchros.
You can buy a hanes manual for info on the synchro, but i was looking at ?pep boys? maybe autozone, i forget which website, but it looked like they had a copy of the manual online, just look for the part where they have recommendations and suggestions on how to fix the different parts of the car.
Well, to get to them you have to take out the tranny, to re-iterate them you just talk about them alot.
Old Jul 25, 2005 | 07:05 PM
rome06's Avatar
Originally Posted by Loe max
Try this:
Push in clutch
release gear
go to neutral
wait a second
ive tried similar to that....i was on the highway going about 65 and i clutch to the floor i took it out of 5th and slowly put it in 3rd and it grinding a little bit but still went in but tiny bit more difficult than it would go into 3rd if i was just driving normally on the street....i tried this a bunch of times and it still does it and im pretty sure that it only grinds when my car is warmed up and i've been driving for awhile, not positive but pretttttty damn sure....but i'll try waiting a second or 2 between my shift tonite and tell u how it goes ...thanks alot man
Old Jul 25, 2005 | 10:21 PM
rome06's Avatar
Try this:
Push in clutch
release gear
go to neutral
wait a second
alrite i went out and tried this and between shifts it barely grinding like im talkin 1-2 clicks (grinds) how ever u wanna call it.....i'll try gettin the redline mt-90 tranny fluid and if that doesnt work then i guese im shiit outta luck
Old Jul 26, 2005 | 05:01 AM
Chickan's Avatar
I would skip the MT-90, and go straight to royal purple. In my Z, the mt-90 helped, but the royal purple damn near fixed the problem. MT-90 is gl-4 weight, and royal purple is gl-5 weight. If it is your synchros, then the heavier weight will extend their life.
Old Jul 26, 2005 | 08:17 AM
rome06's Avatar
but if its too thick wouldnt it feel notchy like aggressivefront said above??
Old Jul 26, 2005 | 08:20 AM
yes 10char
Old Jul 26, 2005 | 12:29 PM
rome06's Avatar
u cant really HEAR the grinding but u can feel it....like i would have a friend in the car and they wont be able to hear the grinding and i would think that they are retarted b/c i can feel it so i imagine that i hear it
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
Socalstillen
Sep 20, 2015 11:46 PM
pktaske
Sep 4, 2015 08:40 AM
