Speed sensor - can't find it anywhere!
Old Jul 24, 2005 | 10:27 PM
tavarish's Avatar
fwd gone rwd cr00
Hey, call this a really dumb question, but where is the speed sensor? i just did the 5spd swap, everything is going well, but the speedometer stays at 0, so i'm guessing the speed sensor must not be plugged in. Where is it located on the 4th gen manual tranny? i'm really anxious to get my car running at 100% with the manual transmission.
Thanks.
Old Jul 25, 2005 | 02:03 AM
trongoc's Avatar
it located on the transmission, you can see it with the battery removed
Old Jul 25, 2005 | 02:11 AM
madnut's Avatar
It is located next to where the right axle goes into the tranny
Old Jul 25, 2005 | 09:16 AM
southeast_first's Avatar
to clarify, it's on the very top of the transmission, in the very back, near the fuel filter (slightly below and towards the passenger side). you can access it just fine from under the hood without removing anything from the engine bay.
Old Jul 25, 2005 | 11:15 AM
Tort's Avatar
if you remove the intake up to the throttle body and look at the back of the transmission you should see a clip surrounded by a 3/4 plastic piece, one bolt and it comes right out, very easy to do
Old Jul 25, 2005 | 12:32 PM
Max96GLE's Avatar
Oh, I had my mechanic changed my speedsensor. You can see it by removing the intake snookle. It's hidden near the starter area. To remove it, you need to jack your car up. You won't be able to see it from the bottom. You have to feel and touch where the sensor is. Locate the sensor from the top and feel it and remove it from the bottom. Good luck
the speed sensor cost around $50 at the dealership.
Old Jul 25, 2005 | 01:41 PM
tavarish's Avatar
fwd gone rwd cr00
thanks, i found it by removing the airbox and MAFS. It was hard connecting it because the engine was very hot, but everything's connected now. Now to hook up the clutch safety switch so my cruise will work...
Thanks,
-Freddy
mrc00l88
Jan 25, 2024 01:14 PM
vingodine
45
May 21, 2016 12:46 PM
Kevin Vanterpool
Aug 29, 2015 05:44 AM
gizzsdad
Aug 19, 2015 01:01 PM
