Does Over Drive use more gas???
Originally Posted by GREENlight
I just wanted to know if O/D used more gas when it's on.
Overdrive is really fourth gear. When you have OD on, the car goes into a taller gear ratio. This means that at any given speed the engine is turning at a lower RPM and is using less fuel. Take a look at your tachometer (RPMs) the next time your driving. When you click the OD button into the ON position above 45mph, you will see your RPMs drop.
By the way, DO NOT turn Overdrive off when you're above 50mph. If you don't know what you're doing you can hurt your transmission. If you don't know how to use your OD on/off button or what it's for, leave your OD in the ON position. It's an automatic transmission, it will do the rest for you.
In a nutshell, leaving Overdrive off will use more fuel. Leaving Overdrive on will use less fuel.
That was beautiful. I was going to reply to this topic but you just gave the best O/D explanation i have ever seen. And btw Greenlight, O/D on will give you slightly less acceleration, so for city driving i would recomend keeping O/D off, but for highway its great.
Originally Posted by Loe max
I'm speachless...
wow, that's crazy. I've never considered O/D to be something that had to be turned on. The way I've always seen it, O/D is on all the time. When I want to lock myself into 3rd gear, I turn off O/D.
Unless, you're on the freeway trying to catch the sun, O/D's safe to leave off. It's unlikely you'll hit the limit of 3rd gear unless you're racing. but.... the only reason to mess with it is if you want more acceleration at high speeds.
just giving my 2 cents. Was amazed at the opposite direction I have for looking at overdrive.
tested at 60mph with cruise control on:
5th gear=33.1mpg
4th gear=28.8mpg
3rd gear=22.8mpg
Both of these were on a flat surface. 4th gear ratio=.94:1 5th gear ratio=.81:1, not a drastic change only a 300-400rpm drop between gears, BUT 3rd ratio is a 1.22:1 and the difference between 3rd and 4th is roughly 1,000rpm at that speed. Not from the same vehicle, but it gives you an idea of how important RPM is to achieve good mpg.
But why? do you get free gas?
Originally Posted by MaxKlinger
You need to read some stickies or go to howstuffworks.com or something and learn how a car works. I'm not here to flame you, I'm warning you to educate yourself before someone else gives you a bunch of crap.
very well explained
...By the way, DO NOT turn Overdrive off when you're above 50mph. If you don't know what you're doing you can hurt your transmission...
Originally Posted by Nissan 6
Is stupider a word?
I must admit you got me there, I thought there was something wrong with the sentence to begin with, or maybe I am getting stupider.
I must admit you got me there, I thought there was something wrong with the sentence to begin with, or maybe I am getting stupider.It's alright my friend. The English language is a complicated beast.
Originally Posted by 97maximaman
...O/D on will give you slightly less acceleration, so for city driving i would recomend keeping O/D off, but for highway its great.
I disagree. I don't think the OD switch has anything to do with shift points. All the OD switch does is enable/disable 4th gear. That's it.
Personally, I leave O/D on all the time unless I'm worried that the AT is going to put me in 4th gear when I need the acceleration that's available in 3rd.
Nah, I spend $60 a week on gas when I drive conservatively. My comment about O/D being safe to leave off had more to do with the poster that said it could be dangerous to turn it off above 50 mph.
Originally Posted by Analog-SE
I knew what overdrive did and all, but I did not know that it could damage the tranny if turned off above 50. What is happening that causes damage. I couldnt find direct info online. MaxKlinger or Anyone have the answer?
Let me first clarify myself. Driving at highway speeds with the O/D off will NOT hurt the transmission (it's not the greatest for the engine, but that's a different story). It's the act of turning the O/D off and downshifting where you will put more wear on the trans. Once the shift is complete, it isn't really a big deal.
Under normal conditions, the transmission only handles load in the direction that the engine is driving the wheels. The only downshifting the automatic transmission does is when you're either accelerating (when the engine is driving the system) or when coming to a stop (in which case the revs are low and the transmission is in a semi-neutral state). In other cases, you'd be downshifting when the wheels are driving the engine (engine braking). Typically automatic transmissions don't hold up as well as their manual counterparts to engine braking. They're not designed to handle much load in that direction. I'm not an expert on this, so if somoene can give a better explanation, please do so. I was just thinking: What happens when the torque converter turbine is spinning faster than the pump? Torque converters aren't designed to operate this way; this might happen the transmission is manually downshifted, and I don't know what effects, if any, would occur.
Originally Posted by maxiquin
you need to go to pep boys and get u some hub caps playa.waaaahaaahaa
Yeah, they keep falling off. I bought two used OEM replacements at one point, but they faded and peeled and look like crap. So, tired of the damn things, I took them off and refinished the steelies with Rustoleum Semi-Gloss Black.
Originally Posted by sunten1
Interesting...I wish the maxi had that real time MPG. My cousins Avalon has it, and I love it to death...
THE WHOLE PURPOSE OF OVERDRIVE IS FUEL ECONOMY.....overdrive is and gear ratio below 1:1 (typically 4th gear on a 5spd) .75:1 would be overdrive this means the motor is moving slower than the speed of the car....but thats a little advanced for you
Why even bring it up if the theory is too advanced for us?
Originally Posted by kosmo886
higher revs= more fuel
not always true, when your torque converter locks up and makes a 1:1 to your engine, the rpms will be higher. say your going 80mph your rpms are about 2700-2800rpms. tap your brakes lightly, and your rpms will drop about 500 rpms. dropping you back into 4th gear.
Well, at least I do ...
Really ... I would've never guessed
