How have you delt with the speed limiter?
I know you can clip the wire on the ECU to remove it but that ends up throwing a code every so often. I was wondering what people with a 99 ECU have done, or is it possible to swap out with another 99 ECU that may not have the limiter. Or does no one have the need to drive over 115? If you have installed a switch, how did you do it? I have read the stickies but am looking for a clean/easy way to remove this.
Originally Posted by NmexMAX
The only time it should be needed is for dynoing purposes only.
But what are some setups any of you guys have done, do you simply just cut the line and install any switch?? Any recommendations on what type of switch to use?
I have 2 SE's, and they go far enough in the triple digits for me ... There are no "set-ups" Take mzmtgs advice, theres not much you can do with it, excpet for what's explained in the stickys.
Originally Posted by PatDezNuts
Yea that is strictly what I am going to use it for.
Originally Posted by zack342
don't speed
the best thing to do is just swap out an ecu with no speed limiter because when u clip the speed sensor wire the car thinks u r going 0 all the time and when u slow down it will make the car stall and just for future reference shift into 5th at 5800 rpm the top of fourth doesn't have enough power
Hey I think I need to trade my non limited ECU with a limited ECU. Any way I can limit it down to say 60MPH?
I keep doing this at any chance I can and seem to have no self control. I somtimes in the middle of the night get on the highway and do this. They say the first step to recovery is admiting you have a problem right?
http://memimage.cardomain.net/member...203_1_full.jpg
how in the hell does everyones car go that fast???
wen i get on the highway late late at night with absolutely no cars on the road and my hands grippin the wheel like theres no tomorrow, (thats the safest way :-)) my car only goes up to 118ish and stops accelerating!! yyyyyyyyyy, i dont have a limiter........ btw, this only happens maybe twice a year as it is very dangerous guys
i do have an auto...ive only gone above that once about a year and a half ago, i was stock then and had changed spark plugs that same day, now im not stock and i stop at 118-119. in 4th it stops at 4k rpms every single time, no lie, u would think it would atleast hit 4200 rpms after puttin on y-pipe, nope! all u guys r quite lucky to even know ur cars pass 120, even though u shouldnt do that
Originally Posted by THT
O/D button? I have no such thing...any more.
We all know that from your half dozen posts about it .. how to drive it etc ...
THT =
Hopefully I'll be there soon ...
That's because you're not leaving the O/D off
I don't understand the dilemma. Cut wire, install switch between the 2 pieces of wire, done. It's not rocket science.
knight_yyz
Nov 1, 2015 01:34 PM
