How Much Do You Spend On Yearly Maintance
Old Jul 26, 2005 | 05:34 AM
Armelius's Avatar
Excluding oil changes and tires, how much do you spend on your Maxima?
Last year I only changed the coolant, transmission fluid and brake fluid. Other than that I haven't spent anything this year.
I am buying a radiator cap though which is about 22 bux.
Old Jul 26, 2005 | 06:08 AM
Chickan's Avatar
well in the past year I've done:
New Clutch $700
New Axles $900
New PCV $6
Fuel Filter $12
Air Filter $80 (new intake)
Acc Belts $30
Front Brakes $140
Rear Brakes $540 (new calipers)
All new seals (valve cover gasket, spark plug tube seals, etc. etc.) $85
Knock Sensor $85
Front O2's $80
Rear O2 $25
New Exhaust $160 ypipe + $300 cat back + $65 high flow cat > $525
O2 Simulator (POS) $30
Plus tons of other stuff not usually considered maintainence, like $800 in car audio stuff, short throw shifter, etc.
Old Jul 26, 2005 | 06:19 AM
njmodi's Avatar
Do I get a tax break?
Chickan -
New Clutch $700
New Axles $900
900 bucks for axles? Did you do that yourself or pay a shop? Axles should not be anywhere near that expensive.
New PCV $6
Fuel Filter $12
Acc Belts $30
Front Brakes $140
540 is way too high if you did the work yourself - right in line with dealer prices (including parts). If you did the work yourself, where did you get the parts? Rear calipers can be bought for 70 bucks a side from www.partsamerica.com, plus another 150 for 2 rotors and 50 bucks for a set of pads... thats still only $340 for everything....
Old Jul 26, 2005 | 07:21 AM
Batxel's Avatar
blah
900 for axles? even if a shop did it you paid double what the average shop would charge. I hope they are top of the line racing axles you couldve saved about 700 bucks and did it yourself.
for me
air filter: $5
trans oil: $40
fuel filter: $12
throttle body cleaning: $3
spark plugs: $60
Old Jul 26, 2005 | 09:09 AM
tallica62's Avatar
i got my car in january, and since then heres about what I spent
- diff. bearings, boot, replaced gear = $1400
- alternator, belts, battery = $800 (i know i got ripped...long story)
- oil changes= $150 (20k miles since january)
- driving my working maxima= priceless
yes that way gay, but i had to
Old Jul 26, 2005 | 09:27 AM
Northern Maxima's Avatar
I bought my Max last October with 82,600 km (51,300 miles) and I'm guessing I've spent around $2700 so far this year (holy crap, now I realize what happened to my salary!!!) plus I still need to add a new muffler to that price soon. I've bought 2 pairs of tires (winter/summer), had the auto tranny flushed, oil changes, replaced front brake pads & rotors, replaced an oxygen sensor, rust proofing...man...I didn't know I've spent so much!!! Thats like a quarter of my annual salary...looks like the car won't be paid off for a loooong time...
Old Jul 26, 2005 | 10:46 AM
naijai's Avatar
man no matter what its not the cost that counts its how well does the car serve yu after all the money spent and mine is giving me a good time 217k and still kicking
Old Jul 26, 2005 | 11:01 AM
MDeezy's Avatar
Basic maintiance Air filters, Oil, fuel filter, so far aroun $200
But in the next couple of month the massive tune up with occur one weekend (or two)
New Clutch (5th gen)
New Tranny (5th Gen)
New Driver side axle
New LCA (Ball Joint) Driver side
Drive Belts
Timing Chain Tensioner
Then in addition
Suspesion
Ypipe
Will be a pretty penny and should feel the max more new than when I bought her.
Old Jul 26, 2005 | 01:31 PM
99Automagic
Last yr, I dropped it off at a shop and told them to do everything. Cost me about 1500. New belts, radiator and tranny flush, tune up, brakes, rotors, alignment, bunch of sensors, and a bunch of other shat. I don't remember. But since then, I've done just a few oil changes and a recent spark plug replacement to keep the car in good working order. The car has been pretty cheap to maintain and very reliable. I have 80k miles on it right now. The way it's going, I should have many more miles to come.
Old Jul 26, 2005 | 04:22 PM
TurTLe*'s Avatar
Right now i haven't spend anything on the maxi. Even tho i only had it for like a month. Planning on doing a couple things here and there. But not too sure on what excatly, with 63xxx i doubt anything is required. Just plan on doing a drain and refill on the tranny when its time to get my oil changed
Old Jul 26, 2005 | 04:24 PM
THT's Avatar
THT
Throbbing member
Very little. I have done all work to my car myself except two things, 00VI and 5spd swap. So really, my only cost is parts which are relatively cheap online.
Old Jul 26, 2005 | 07:33 PM
Just noticed today that something is hanging off the bottom of my car and dragging on the ground (exhaust maybe?). The car is sitting at the mechanics for tomorrow so I guess my $2700 will grow...hopefully not too much!
Old Aug 7, 2005 | 01:23 AM
Bruin's Avatar
$0 =)
Though $300 for 60k tuneup last year, that's about it.
Old Aug 7, 2005 | 01:37 AM
PoKKi's Avatar
Got my Maxima with 190000km in December.
Rust Proofing $130CDN w/ tax
4 New Bridgestone G009 mounted,balanced, etc $890CDN w/ tax
New radiator installed $419CDN w/tax
Oil change with TB cleaning $80CDN w/ tax (I'm lazy ok)
New K&N Filter $80CDN w/ tax
Well the tires that they had on were crappy as hell. Some "USED" snow tires. Didn't realized the radiator leaked up top. But these aren't really routine.
Old Aug 7, 2005 | 02:23 AM
Ruthless's Avatar
All CDN $
spark plugs = $60
fuel filter = $30
altranator = $400
starter = $450
burnt light bulb = $2
attenna = $23
Heated seat light = $5 (any many swears installing)
oil changes = $54 a time... 20k since Dec
OH, and I paid $1.03 a litter for gas last night
rear o2 sensor = $130
fog lights (one burnt out) = $99
tones of cleaning stuff = ?$200??
rubber = $880 (new rims... does not really count)
roters machined= $40
front and rear pads = $280
pressure switch = $92
fog light housings = $230
Plus mods and what not, they dont count.
Total for everything (car included)except insurance is about $23,000
Bought in Dec.
Maxboy23
55
May 1, 2025 06:09 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ik95
Sep 16, 2015 08:11 PM
I<3 A32's
Sep 10, 2015 11:07 AM
