Removing back coil packs
Old Jul 28, 2005 | 04:10 PM
Nick7455's Avatar
Well, I am changing my plugs for the first time on my own....easy as hell but for the back coil packs they are angled too much to pull them out...plus the strut bar is in the way.
I saw on the How to's that the person actually unplugged the coil pack to remove it unlike with the front packs....how the hell do you unplug the connections......It is just like the windows switches....it is a ***** to press the button down and try to pull it.....do you guys know of any tools that can help pull coil pack connection out? I just can't get a good grip on it...
Old Jul 28, 2005 | 04:19 PM
konak85's Avatar
a flathead screwdriver or wear gloves
konak85's Avatar
you might have to unbolt the thing obstructing the rear right coil pack, then bolt it back when done.
Old Jul 28, 2005 | 05:26 PM
njmodi's Avatar
Do I get a tax break?
You'll have to remove that bracket (2 nuts) to get Cyl #5 coil pack off. You might have to pull the FSTB off too...
Old Jul 28, 2005 | 05:32 PM
Nick7455's Avatar
yea... got the bracket off..Also used gloves but still didn't provide enough grip..just couldn't unplug the coil packs.....Somehow I did it with some plyers and being extremely careful not to apply much pressure...Car runs a lot smoother now! thx for the replies.
Old Jul 28, 2005 | 08:30 PM
99Automagic
Get a screw driver, push in the green part all the way in until it's stuck there with out you having to apply pressure to keep it there. It will "click" when you reached the release point. Then it should just pop off. It actually makes a "pop" sound. And the rest...do what njmodi said. That coil pack that's farthest to the right, closest to the firewall. You need to remove that metal bracket that's on top of the coil. Two nuts, 12mm I believe.
Old Jul 28, 2005 | 08:35 PM
tavarish's Avatar
fwd gone rwd cr00
take off the fstb. unbolt everything else that's in the way. It should be cake. You can pull the switch out with pliers.
Old Jul 29, 2005 | 06:19 AM
Loe max's Avatar
I'm with tavarish! Pliers are your friend with the rear coils.
Old Jul 29, 2005 | 06:25 AM
MaximaSE96's Avatar
Maxima Owner
i had no trouble with mine.....the connection plugs that is....u do have to rearrange things to get a couple of the rear ones off
JRod28
Dec 29, 2023 09:56 PM
vingodine
45
May 21, 2016 12:46 PM
Maxboy23
Aug 21, 2015 11:02 AM
kirkhilles
Aug 8, 2015 10:53 AM
