Diy Hyperground Kit Help Please!!
Old Jul 29, 2005 | 07:21 PM
cefiro8701's Avatar
what gauges should be used??how many feet of wire is sufficient and how do i connect these wires to the negative battery terminal??
where should i buy the wires from??the audio section of radio shack??
i cant seem to piece this one together...if this is a repost please point me to the right direction and i'll delete this thread.
Old Jul 29, 2005 | 10:20 PM
cefiro8701's Avatar
can't believe this...no help?
Old Jul 29, 2005 | 10:21 PM
SchismistiC's Avatar
I's help if i had one :S or if i knew what to do :P But ill keep ya in mind :P
Old Jul 29, 2005 | 10:47 PM
cefiro8701's Avatar
dang...its been bugging me for weeks...i don't know what i should use.
Old Jul 29, 2005 | 10:54 PM
Jeff92se's Avatar
I'm needing a caw
Just buy one from Matt93se. If you THAT lost about how to make one, his kit will save you way more time and $. It's not expensive either.
Old Jul 30, 2005 | 12:36 AM
99Automagic
http://www.vqpower.com/v2/modules.ph...rticle&sid=149
Look here too. This is what I have installed.
Old Jul 30, 2005 | 01:00 AM
Tyrexx's Avatar
do NOT buy wire at radio shack.
Old Jul 30, 2005 | 09:04 AM
cefiro8701's Avatar
someone point me toward matt93se??
Old Jul 30, 2005 | 09:11 AM
99Automagic
http://www.mattblehm.com/enginegrounding.htm
There you go.
Old Jul 30, 2005 | 09:12 AM
Jatan's Avatar
http://forums.maxima.org/showthread.php?t=412217
Old Jul 30, 2005 | 12:24 PM
cefiro8701's Avatar
any cheaper...i heard it can be done for around 30 dollars...
Old Jul 30, 2005 | 12:55 PM
Ka$hThaRipper's Avatar
^^ so matt93se's prices are 40 bux...and u say u want it for around 30 bux
r u serious?
Old Jul 30, 2005 | 01:34 PM
99Automagic
No, none at that quality come cheaper than 40. Make it yourself if you want to save the 10 bucks. You've seen a few of the examples now and you should be aware of what it takes to make a set.
Old Jul 30, 2005 | 06:18 PM
bhmax16's Avatar
If you don't even know how to connect the wires to the battery terminal, etc.. then you shouldn't even attempt to make your own kit. But to help you out...I got all my cable at Lowe's (but Home Depot would be fine as well). I used 4 gauge and 6 gauge cables, but you can use any gauge you want (Matt uses 4 gauge for the battery ground and 8 gauge for everything else). I bought 4 feet of 4 gauge and 15 feet of 6 gauge and could use a bit more of the 6 gauge to ground everything I want to ground (keep in mind I'm going a bit overboard with my kit but I'd rather have the piece of mind knowing I covered my bases). Goodluck
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
