16 MPG = bad KS?
Old Jul 31, 2005 | 04:20 PM
RockfordMax's Avatar
Back from the dead
16 MPG = bad KS?
alright this last tank (93 of course) i drove like my mom and probably never hit 0-30 faster than 5 seconds, with 33F/32R inflation tires, temps were 80 all week, plugs are like 6k old, but yeah, everything was in good shape, but as i did the math i got 16 mpg (206 miles on 12.8 gallons) but yeah, something is wrong. 121k miles, im guessing its the KS. where is a good place to find one ( and harness if it is needed) and is this MOST LIKELY the problem? thanks in advance guys
Old Jul 31, 2005 | 04:23 PM
4x4Max's Avatar
It might also be the o2 sensor. Why don't you drive to autozone and pull codes for free?
Old Jul 31, 2005 | 05:26 PM
1996blackmax's Avatar
He could also just check the codes himself. It's pretty easy.
Here in California they do not do that service anymore. Some new legislation or something. We tried a few different places for my sister's 2000 Max and they all said that they are not allowed anymore.
Old Jul 31, 2005 | 05:48 PM
Back from the dead
forgot to mention that i did check the ECU not only with the CEL flash method but with a scan tool, no codes.
Old Jul 31, 2005 | 06:17 PM
deezo's Avatar
There's a lot of things that could cause bad mileage. Have you changed the fuel filter lately?
Old Jul 31, 2005 | 06:22 PM
Back from the dead
yeah i replaced everything that showed any sign of wear at 115k when i got the car.
Old Jul 31, 2005 | 06:26 PM
Dragging brakes can also effect gas mileage.
JwaxMax99's Avatar
Anything that showed signs of wear? And just what were these parts?
Old Jul 31, 2005 | 06:29 PM
smokeyone's Avatar
Everything, as in: spark plugs, air filter, fuel filter, clean TB and IACV and so on and so forth? Also, how exactly are you figuring your gas mileage? What are your driving habits? No offense, but seeing your 16, I'm guessing this is your first car and you may have a lead foot. Driving style greatly affects gas mileage. Oh, hows your tire pressure? How about a stereo or something else heavy in your car. We need more information.
Old Aug 1, 2005 | 05:57 AM
laylow1988's Avatar
[QUOTE=RockfordMax]alright this last tank (93 of course) i drove like my mom and probably never hit 0-30 faster than 5 seconds, with 33F/32R inflation tires, temps were 80 all week, plugs are like 6k old, but yeah, everything was in good shape......
Old Aug 1, 2005 | 08:51 AM
Bobo's Avatar
Were you running the air conditioning during the entire tank? If not, were you driving with the windows rolled down?
Old Aug 1, 2005 | 10:28 AM
MDeezy's Avatar
even with AC on full blast it would lower his gas milage that much. I've gotten excellent mpg on a 4 hr trip AC the whole way.
Air filter can give some pretty bad consuption, if not thats not it then . . .
Old Aug 1, 2005 | 11:13 AM
dr-rjp's Avatar
I'm assuming your car is an automatic.
If it is and all those miles were in "stop-and-go" city driving, then I would not worry about it. Test it again, and I bet your mileage will be higher.
This time, however, you need to go at least 250 miles before filling it up. The further you drive, the less error there will in your calculations. I would also make sure that you only fill it up in the early morning when it is coolest and before the gas in your tank has had a chance to vaporize. You'd be surprised how much that built-up gas, vapor can throw off your calculations.
Going too slowly from a dead stop can also waste gas because (1) you use more gas accelerating in lower gears than cruising in high, and (2) you spend most of your gas trying to overcome the drag on your car that occurs at lower speeds.
In other words, if you are taking 5 seconds or longer to go from 0 to 30, you're wasting gas in the process!
Old Aug 1, 2005 | 11:23 AM
Jatan's Avatar
Replaced oxygen sensors? Was getting 16-18 and now I'm getting 20-22 with new O2s
Old Aug 1, 2005 | 02:14 PM
PoKKi's Avatar
I know I'm gonna get flamed by people but whatever. I used a bottle of Quakerstate FI cleaner into my tank and using 87 octane gas (ready to be burnt) I have over 300 miles on my tank. And I do mostly city driving too. Sometimes I drive like a granny...but with occassional lead footedness. Perhaps try a bottle of FI cleaner.
Old Aug 1, 2005 | 04:14 PM
jordandalley's Avatar
The KS can have a large adverse effect on the overall performance. You can bypass the KS with a 720k resisitor. There is a post somewhere in this forum about doing that. This is for only finding out whether it is the problem or not.
Old Aug 1, 2005 | 05:47 PM
Back from the dead
^^thanks ill try that on a ride or something, but yeah my car is competely stock, ive been maintaining it for a year between my dad getting his 04 and me getting my license all the while on the org, and i basically did the 60k service... but yeah i was exxagerating a bit with the 0-30 in 5 thing. of course i have a lead foot, but for this test i eased up a lot to try to get the best mileage. im testing again on this tank, and ill test the KS. are there any other symptoms of a bad KS? because now that i hear about "replaced my KS, hesitation gone" it sounds like my problem. im posting tired, so ill cut myself off now
Old Aug 1, 2005 | 08:56 PM
smotz's Avatar
Brain phuck
With my a/c blasting nonstop I get 25-28 mpg on my 5 spd. Back when it was cooler and I didn't use the a/c I would get 34-42 mpg. And I don't drive like a granny
Old Aug 1, 2005 | 09:38 PM
jaroque's Avatar
wanh. i got less than 20mpg on this tank with my 5spd. and i did a lot of highway cruising.
Old Aug 2, 2005 | 11:00 AM
dr-rjp's Avatar
Was the engine running at the time?
chisam14
Nov 6, 2018 08:56 PM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
